CHECK ENGINE LIGHT ON BUT NO CODE....... SEARCHED
I was throwing 3 codes and I fixed them all. The three were map sensor, tps sensor, and the iat sensor. Once they were all fixed the the check engine light came on 2 minutes later. I disconnected my battery and disconneted my ecu. So when I go to check my codes with the wire it doesnt flash or anything. The check engine light just stays. Any help appreciated I searched and no info related to my issue
motor is a obd 1 h22 running crome.
i have heard when the check engine light just comes on when u jump it, usually means bad ecu. try unplugging everything again. then check the code again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbociviccoupe »</TD></TR><TR><TD CLASS="quote">we have that problem and it usually means a bad chip</TD></TR></TABLE>
or that 2
or that 2
kaoss_11
Sep 10, 2006 12:03 AM
ph0shizzle
May 13, 2006 08:36 PM
