Dizzy O-Ring..anybody know about this?
Old Sep 9, 2006 | 12:49 PM
HNP's Avatar
HNP
Default Dizzy O-Ring..anybody know about this?
whats up h-t my car had some oil all over the tranny and i looked around and found that my dizzy o-ring was fucked up so i replced the sucker, do i get a better oil pressure?? or it does nothing but to stop the oil from goin everywhere? and if u leaking by the vtec solenoid does that make u loose oil pressure? or is it just a leak?? thanx
Old Sep 9, 2006 | 01:37 PM
HNP's Avatar
HNP
Default Re: Dizzy O-Ring..anybody know about this? (HNP)
bump....
Old Sep 9, 2006 | 03:11 PM
HNP's Avatar
HNP
bump again....theres no one on h-t today
Old Sep 9, 2006 | 03:26 PM
instructor74's Avatar
the O ring is jut a seal between the distributor and the head. The vtec seal leaking might cause a slight drop in oil pressure i sm not sure if it enough to cause a huge lose of pressure. You might want to make sure the distributor oil seal is not leaking. Take the dist cap off and look for oil inside it if there is you need to replace that seal also
Old Sep 9, 2006 | 03:36 PM
1992Si's Avatar
You should not be getting oil inside the dizzy.
If you have Honda http://www.hondautomotiveparts.com is a good place to get OEM for cheap.
They have link to a Acura site.
You can also replace the spool valve gasket, that's the seal for the Vtec valve. For a D16 there like $14.00.
If you buy from Majestic place a big order and make it worth the effort. When was the last time you replaced the plug wires cap and rotor?
Old Sep 10, 2006 | 04:31 AM
HNP's Avatar
HNP
Default Re: (1992Si)
thank you very much guys, i have already replaced the O ring for the dizzy, by the way i have a jdm b16....
Hondablues74
Jan 6, 2019 07:59 AM
B_Swapped93
Jun 14, 2013 12:45 PM
Honda_Accord
Apr 7, 2008 09:32 PM
vtec.dc2
Mar 9, 2004 04:41 AM
toooslow
Oct 19, 2003 04:05 PM
