I just bought a boosted gsr and have a ?
Old Sep 9, 2006 | 12:28 PM
gsober's Avatar
Default I just bought a boosted gsr and have a ?
i turned on the car to drive it home and all is fine but i notice that the fans are on. should they be running all of the time? i have a gsr with jrsc. is there a relay that is bad or is it set up to run all the time with the SC?
thanks
Old Sep 9, 2006 | 12:46 PM
zexifiedlude's Avatar
they are probably just hooked on a switch for the when car starts so that they are always on, probably an over heating problem
Old Sep 9, 2006 | 01:40 PM
gsober's Avatar
i think it is not an overheating problem. i emailed PO and he said it may be something else. ...i hope
Old Sep 9, 2006 | 02:05 PM
Dc4turbo408's Avatar
Default Re: (gsober)
Naw, He taped it, so it can be on all time..
I taped mine to a half size radiator.. It helps.. If im you just leave it alone and dont worry about.. Even if it doesnt overheat it still good for your car..
Old Sep 9, 2006 | 05:59 PM
M.A.R.C.'s Avatar
Default Re: I just bought a boosted gsr and have a ? (gsober)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsober &raquo;</TD></TR><TR><TD CLASS="quote">i turned on the car to drive it home and all is fine but i notice that the fans are on. should they be running all of the time? i have a gsr with jrsc. is there a relay that is bad or is it set up to run all the time with the SC?
thanks</TD></TR></TABLE>
you can jump the radiator fan plug to have it stay on all the time. i've had mine like that before. as for adverse effects, I don't think there are any other than it might wear out the fan quicker.
Old Sep 10, 2006 | 04:35 AM
gsober's Avatar
does it draw any "extra" power?
Old Sep 10, 2006 | 04:48 AM
bdavis's Avatar
the guy probably did it cause his fan switch died and he didnt want to spend the $20 to replace it. its the bronze looking plug on the thermostat housing. replace that and it will be all good. your fan always on is bad. it takes longer and sometime never will reach the correct operating temperature
Old Sep 10, 2006 | 06:50 AM
gsober's Avatar
the plug is what i am replacing?
Old Sep 10, 2006 | 07:15 AM
bdavis's Avatar
the engine coolant temperature on the thermo housing. its a bronze looking sensor. you can make the fan run all the time by jumping its connector
Old Sep 10, 2006 | 07:28 AM
nfn15037's Avatar
Default Re: (Dc4turbo408)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dc4turbo408 &raquo;</TD></TR><TR><TD CLASS="quote">......it still good for your car.. </TD></TR></TABLE>
How is it good for your car to take longer than normal to come up to operating temp? If it was so good Honda would have had the fans on all the time from the factory
Old Sep 10, 2006 | 07:54 AM
gsober's Avatar
how do i put it back to normal? any DIY articles about that?
Old Sep 10, 2006 | 01:39 PM
nfn15037's Avatar
You probably need a new thermo switch (like others have said). There aren't any DIY articles that I know of, but if you want to do any work on your own you should purchase a factory service manual.
4dek
10
Jun 15, 2008 09:26 PM
MaGoodc2
Mar 26, 2006 11:22 AM
leira619
Aug 7, 2003 07:06 PM
Anyotherone
Jun 19, 2003 02:56 PM
MooreBoost
May 8, 2003 02:48 PM
