Which 4channel amp should i get??? help me out guys
Here is my setup
JL cleansweep
200 watts rms - diamond audio D661i 6.5" HI END Coaxial
125 watts rms - a/d/s 345cs 6.5" 2way component
Now which 4channel amp should i get for these speakers??
I think i have narrowed it down to 3, but fill free to suggest something.
4ohm: 120x4 watts rms - Kicker 06ZX650.4 -$180-240 range
4ohm: 100x4 watts rms - Phoenix Gold X100.4 Xenon - $200-250 range
4ohm: 75x4 watts rms - PPI DCX 600.4 - $180-210 range
Are these good amps that i have listed??
Need inputs. Thanks a lot!!!!
JL cleansweep
Actually both sets of speakers are 100W continuous and I would suggest the JL Audio 450/4 and use the Diamond Audio C66.1mx3 mid-bass driver for the rear, or just disable tweeter in the D661i, [you do not want tweeters behind you] and run them as rear fill only and why not use the A/D/S 346cs components.
94
94
woah...the JL audio 450/4 is out of my budget... $599.00 lol
do you think the ppi with 75 watts to each speaker is efficient?
oh okay, well thx fmc
i ended up buying the Kicker 06ZX650.4 since it has more power than the ppi
120 watts rms...should be okay for now for my budget. i hope (fingers crossed)
