Crx si motor
Old Sep 9, 2006 | 11:49 AM
lilsoysauceracer's Avatar
Default Crx si motor
I got honda crx that i really need help on...everything is fine but the only thing that is wrong with it is when the rpm are low...its has a hard time to keeping it alive...but when the rpm are high it runs ok.. i dont know what it is...all i have in mind is the fuel pump but im not sure....And i have another thing about the computer chip....its reading code ten...what will cause it to do that...please anyone help
Old Sep 9, 2006 | 12:03 PM
hondadude's Avatar
Default Re: Crx si motor (lilsoysauceracer)
code ten is a problem with the intake air temp sensor
Old Sep 9, 2006 | 12:08 PM
Tippyman's Avatar
Yeah, fix that code before you even worry about fixing anything else. That is most likely your problem.
Old Sep 9, 2006 | 12:09 PM
Default Re: Crx si motor (hondadude)
I know that, but what would cause it to do it...
Old Sep 9, 2006 | 02:28 PM
wiZCo's Avatar
Stouts 'n' Scotch
A bad IAT sensor or bad wiring. Do you have a repair manual? If so, check the procedure for testing in there. If not, more than likely you need to change it anyways, just get a new one.
1POS_CRX
10
Feb 28, 2011 03:37 PM
romierome
Feb 24, 2010 12:01 AM
4gnhatch
Dec 18, 2006 03:20 PM
hondacrx
Feb 7, 2004 02:26 PM
