1990 CRX Code 10 Help
Hi guys I'm new here but not that new to Hondas.
Just picked up a 90' CRX with a d15b and need to get it smoged. The car was originally throwing codes 1, 10, and 14. I replaced the o2 sensor, cleaned out the IACV, and installed a new autozone Intake Air Temp Sensor. Now it's only throwing code 10 but I don't get why as I its a new temp sensor. If anyone can help it will be greatly appreciated.
-Jon
-Jon
Re: 1990 CRX Code 10 Help
-Jon
1. Get out your multimeter and wire diagrams.
2. Disconnect negative battery cable.
3. Disconnect the MAF connector
4. Using the wire diagram find the other end of each of those wires and test for continuity (Ohms) by putting a lead from the multimeter on each end of the wire.
If it is a wire, just run a new one using the same diameter wire.
probably has the wrong connector plugged into the IAT sensor - should be a white 2-wire connector with red with yellow stripe and green with white stripe wires
-Jon
does the connector currently plugged in have a red with yellow stripe wire and a green with white stripe wire? if it was originally DPFI, the harness should have a connector that looks just like the one for the IAT but has 1 orange wire and 1 black/yellow wire - this connector should go nowhere - if it was originally the Si model, it will also have a connector that looks just like the IAT connector - it has 1 blue wire and 1 black/yellow wire
Keyboard Humorist
NOOOOO!!! Buy a new OEM MAF or...
ppl talk bout my old name
04-19-2006 07:23 PM
Waachback
12-02-2003 06:56 PM
