6-speed D?
Old Sep 9, 2006 | 10:54 AM
whiteknightef's Avatar
Default 6-speed D?
is there a 6-speed sohc tranny that came in the wagons?
Old Sep 9, 2006 | 11:29 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: 6-speed D? (trigger69)
Yes.
Old Sep 9, 2006 | 01:11 PM
JJ's civic's Avatar
Default Re: 6-speed D? (wiZCo)
is it good on gas? and wa it in the civic wagon?
Old Sep 9, 2006 | 01:21 PM
Tippyman's Avatar
Default Re: 6-speed D? (joeny12985)
I've never heard of a 6-speed D tranny. unless you count reverse... lol.
Old Sep 9, 2006 | 01:28 PM
JJ's civic's Avatar
Default Re: 6-speed D? (Tippyman)
aither have i but sound like it would be better on gas...
Old Sep 9, 2006 | 01:37 PM
justseeingifitistaken's Avatar
i believe the wagon awd came with a six speed but the 6th speed isnt a higher gear but a very LOW gear.
Old Sep 9, 2006 | 03:54 PM
Tippyman's Avatar
Default Re: 6-speed D? (hondaJDMimports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaJDMimports &raquo;</TD></TR><TR><TD CLASS="quote">i believe the wagon awd came with a six speed but the 6th speed isnt a higher gear but a very LOW gear.</TD></TR></TABLE>
Odd. Maybe it could be swapped out... A 6-speed D tranny with close ratio gears and a really high final drive would be sweet!
Old Sep 9, 2006 | 04:04 PM
yeah but 4 wheel drive and axles are different and weaker i believe. differential notorious for going out too. got a local guy here i know that has replaced it three times.
Old Sep 9, 2006 | 04:14 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaJDMimports &raquo;</TD></TR><TR><TD CLASS="quote">yeah but 4 wheel drive and axles are different and weaker i believe. differential notorious for going out too. got a local guy here i know that has replaced it three times.</TD></TR></TABLE>
Yeah, the part of the drivetrain that transfers power to the rear usually breaks.
Old Sep 9, 2006 | 05:30 PM
jhota's Avatar
yes, they did have a "Super Low" first. when selected, it was not only an insanely low stump-pullin' gear, it "locked" the car into "4wd." just like engaging the lever under the hood.
Old Sep 9, 2006 | 10:55 PM
Default Re: 6-speed D? (jhota)
yes but all of that can be swapped out! i am a mechanical engineering grad student at WSU and i am going to work on converting that transmission to a race tranny as one of my projects. I have been interested in finding out if they really exist? Now that i know they do the sky is the limit for me!!!!!!!!!!
Old Sep 12, 2006 | 08:26 PM
anyone know where i can find one or if anyone has tried to manipulate the gearing on one?
Old Sep 12, 2006 | 09:06 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trigger69 &raquo;</TD></TR><TR><TD CLASS="quote">yes but all of that can be swapped out! i am a mechanical engineering grad student at WSU and i am going to work on converting that transmission to a race tranny as one of my projects. I have been interested in finding out if they really exist? Now that i know they do the sky is the limit for me!!!!!!!!!! </TD></TR></TABLE>
if u do this, PM ME! i'm interested in this...
BTW: lol at the thought of a wagovan pulling stumps!
Old Sep 13, 2006 | 09:07 AM
ya thats a funny thought. For real though im going to do this so be prepared for a sohc 6-speed crx
Old Sep 13, 2006 | 09:25 AM
charlee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">
x2
Old Sep 13, 2006 | 09:27 AM
civicandy's Avatar
my guess it would be cheaper to swap in a kseries with a 6 speed than i would be to convert a wagon tranny to work in 2wd as a 6 spd.
Old Sep 13, 2006 | 09:39 AM
Super Chicken's Avatar
Default Re: 6-speed D? (civicandy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicandy &raquo;</TD></TR><TR><TD CLASS="quote">my guess it would be cheaper to swap in a kseries with a 6 speed than i would be to convert a wagon tranny to work in 2wd as a 6 spd. </TD></TR></TABLE>
Ya I agree with this statement. It can be done, but how much do you want to spend to make it work.
Old Sep 13, 2006 | 10:45 AM
civicandy's Avatar
Default Re: 6-speed D? (Tyson)
i belive the 4wd wagon has 5 spds, plus a low range for 1st. so 6 spds. is this correct? the 2wd fwd drive is just a d series tranny
Old Sep 13, 2006 | 10:49 AM
Tyson's Avatar
well goddam! it does have some extra "low" gearing.
but its also meant for 4wd. so who knows if its at all compatible.
wow, check out that diff! 2 diff gears (FD).
no surprise, it looks like the CR-V diff.
Old Sep 13, 2006 | 10:56 AM
civicandy's Avatar
i think the actual tranny would work in a fwd, but the extra gear would probably not. even so, it would not serve any purpose
Old Sep 13, 2006 | 10:57 AM
civicandy's Avatar
i think the actual tranny would work in a fwd, but the extra gear would probably not. even so, it would not serve any purpose. it really only has 5 forward gears. if you wanted a faster d series tranny, get a zc one, with an si final and an hf 5th. i believe that is the right combo
Old Sep 13, 2006 | 10:58 AM
Tyson's Avatar
i totally agree.
just interesting.
Old Sep 13, 2006 | 03:00 PM
Cvic90's Avatar
It will bolt up to the engine. I don't know if the mounts will work though. My brother has an 88 AWD wagon. the axles are different too. You have to have an engine with the 3 bolt flange on the back for the mid shaft. Also, the wagon trans has cable shift linkage like the accords and preludes. the weakest part of the drivetrain is the driveshaft. the diff bearings and transfer case fail becaz they don't get the oil changed with Honda MTF as often as they should.
Old Sep 13, 2006 | 03:13 PM
Tyson's Avatar
Default Re: 6-speed D? (Cvic90)
interesting. totally different shift linkage setup indeed.
Old Sep 13, 2006 | 04:30 PM
STREETWERKZ's Avatar
could be a cool thread if someone actually did this.
