blown 7.5 fuse...
i keep blowing my 7.5 (instrument panel) fuse. i've replaced it 3 times and every i keep getting the same outcome. as soon as i turn my ligths to the on position it blows out right away. what do you guys think is the problem? i cant monitor my speed at night!!
i hooked up my kill switch once again. it's connected to my fuel pump, and also my radio wires are all jakced up, some arent connected some are. could that be the problem? but why my instument panel fuse?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xd69 »</TD></TR><TR><TD CLASS="quote">i hooked up my kill switch once again. it's connected to my fuel pump, and also my radio wires are all jakced up, some arent connected some are. could that be the problem? but why my instument panel fuse?</TD></TR></TABLE>
it's all tangled in together. repair your radio wires, whatever you're not using tape up. also double check the wiring to the kill switch. these minor repairs should solve you're fuse problem.
