Best way to align Mugen shift knob
Old Sep 8, 2006 | 01:27 PM
OMG THE GOGGLES's Avatar
Default Best way to align Mugen shift ****
I have the Mugen *****. I need an easy way to align it, thread tape isnt working too well. I am used to having ITR ***** with the reverse threaded nut and switched over to the mugen because of the lower drop since the threads start 3/4 the way up the ****. Whats your suggestion, a nut cannot be used, and thread tape...maybe I didnt take enought time..but its not really stopping it from going any farther.
And yes, the mugen *****
Modified by gasp0matikz at 9:14 PM 9/8/2006
Old Sep 8, 2006 | 02:43 PM
CarbonizedDX's Avatar
Default Re: Best way to align Mugen shift **** (gasp0matikz)
find something circular that will fit loosely inside the shifter and just find which keeps the shifter up just enough to align the logo....... Make sure it's a solid mass (like wood disc or plastic or metal of some flavor, so you can crank it down and have it stay tight.
Not really sure what else will work..... but that's the simplest idea I came up with.
Old Sep 8, 2006 | 08:14 PM
Default Re: Best way to align Mugen shift **** (CarbonizedDX)
Cool, Thanks :D
Old Sep 8, 2006 | 08:17 PM
Rev2Eight's Avatar
what type of material is that **** made from?
Old Sep 8, 2006 | 08:27 PM
nsxmatt's Avatar
Sounds cheap but I would use little bits of straw wrapper. I would keep adding little by little till when it was snug it was in the right position.
Old Sep 8, 2006 | 11:08 PM
Default Re: Best way to align Mugen shift **** (nsxmatt)
Well, I sell hardware...so Im sure I can come up with some thin and very small diameter washers to make the space
Old Sep 8, 2006 | 11:31 PM
__oversea's Avatar
weld the nut on the bottom of the **** that fit on your shifter thread, and put another one on the shifter. then tight them together.
Old Sep 9, 2006 | 09:03 AM
Default Re: Best way to align Mugen shift **** (BrownEyed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrownEyed &raquo;</TD></TR><TR><TD CLASS="quote">weld the nut on the bottom of the **** that fit on your shifter thread, and put another one on the shifter. then tight them together. </TD></TR></TABLE>
Only thing is, the threads start halfway up the shifter, not at the bottom like the ITRs that I am used to, it would work for an ITR by just using a nut..but, not with this applicaiton, ill have it all done today though, easy fix, good idea from carbonizeddx.
Old Sep 9, 2006 | 10:06 AM
always glad to help.
Nihilus
Mar 28, 2005 12:25 PM
Kengs
Nov 7, 2002 11:37 AM
Wiseguy
Aug 24, 2002 07:05 PM
