My stock lca's are a bitch to get off.. Need help
Old Sep 8, 2006 | 12:32 PM
Usdmowns's Avatar
Default My stock lca's are a bitch to get off.. Need help
is there a easier way to get them off.. Should I drop the struts.
Old Sep 8, 2006 | 12:38 PM
gsxr1k05's Avatar
get the nuts nice and lose on both ends first, then get a hammer to tap when u need to.
Old Sep 8, 2006 | 12:43 PM
ILcrxsi1's Avatar
I tell doctors what to do
Default Re: (gsxr1k05)
If the bolts are seized it's not going to come out easy any way you slice it(pun intended)
Old Sep 8, 2006 | 02:00 PM
rsca_crx's Avatar
Default Re: My stock lca's are a bitch to get off.. Need help (WideBody96)
front or rear?
what exactly is giving you a problem?
Old Sep 8, 2006 | 02:13 PM
HondaHeddie's Avatar
try reading the faq
here is what it would tell you
https://honda-tech.com/zerothread?id=1544731
Old Sep 9, 2006 | 09:46 AM
Usdmowns's Avatar
^ thats for ball joint bro..
the rear. I go the bolt and such out the hib and the only one that are on is the strut bolt and the bolt and nut that connects it the rear end....I got the nut off the strut bolt but the bolt wont come out\I hammered and hammered it to get it out. and no luck would be more help to me to drop the strut
Old Sep 9, 2006 | 12:26 PM
ILcrxsi1's Avatar
Default Re: (WideBody96)
your bolts are seized in the center sleeve of the bushings. same **** happened to me with every one of my control arm bushings in the front and back. you are in for a real pain in the ***. get a sawzall and good luck
2wheelhunter
Sep 3, 2006 10:00 AM
god.loves.ugly
Mar 17, 2006 08:38 PM
thaimonkey
15
Jul 7, 2005 10:42 AM
boostin4drcivic
Apr 18, 2004 03:57 PM
Nader_D
Sep 8, 2003 12:57 PM
