AC bracket removal
I am doing a wire tuck to my GSR. I eliminated my AC lines and I want to eliminate my condensor but keep power steering. I have looked at this article https://honda-tech.com/zerothread?id=1693934 and it seems to be that no one has the drivers side lower motor mount bracket that is behind the AC compressor. Do you need this bracket or could i remove it w/o having any problems? Thanks
I have had mine off for a while without any problems
there are 4 bolts, remove them and then a 17mm nut on the bar that goes throguh the mount on the chasis, just remove the nut after the bolts on the block are out and the bracket should come right off
You can run without but it is best to keep it as it serves as a vibration mount. Unless you have upgraded mounts elsewhere, I highly suggest running it.
Just get the JDM aluminum one and it'll be bling
Renegade
Jan 28, 2005 07:39 AM
NeXtLeVeL_TyPe_R
Nov 24, 2002 07:47 PM
