1996 GSR motor into 1999 Civic Si...ECU/dizzy/harness issues?
Old Sep 8, 2006 | 08:32 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default 1996 GSR motor into 1999 Civic Si...ECU/dizzy/harness issues?
My buddy's about to drop in a 96 GSR motor into a 99 Civic Si, and we have a couple concerns. The motor, dizzy, ECU, etc. are OBD2a. The Si harness is OBD2B.
How can he make it all work? The only other swap I've done is my OBD2a GSR motor into my OBD2a Civic.
Old Sep 8, 2006 | 10:50 AM
wakeboard_dude5's Avatar
Default Re: 1996 GSR motor into 1999 Civic Si...ECU/dizzy/harness issues? (boostincoupe)
buy an obd2a to obd2b harness and you should be fine. Although i'm not too sure about the dizzy but i would assume its the same
Old Sep 10, 2006 | 08:34 AM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
i believe the engine harness on the 99 SI should be plug and play. The only thing u would have to wire up is the secondary butterflies (IAB). Also u will need a conversion jumper harness from obd2b to obd2a for the ecu
tommyboy042281
21
May 4, 2009 06:20 PM
97accord_R
Mar 19, 2009 03:47 AM
Superdragr45
Apr 27, 2005 09:28 PM
alltech
May 18, 2002 10:28 AM
