opinions about ebay LSD
Old Sep 8, 2006 | 08:30 AM
zenon8890's Avatar
Default opinions about ebay LSD
i searched and found some stuff but not my questions i'm about to ask, i'm going to buy obx lsd for my crx d15b turbo! i'm suffering a mega burn out problem that i cant launch it right, i heard that OBX lsd could have a problem when changing the axil, they say it get stuck in the LSD! i dont have much money to get a real deal LSD, so will the ebay lsd's work fine?!
options one (very wierd looking)
http://cgi.ebay.com/ebaymotors...QrdZ1
optione two
Old Sep 8, 2006 | 08:54 AM
aXhatch's Avatar
Default Re: opinions about ebay LSD (zenon8890)
OBX when they first came out with LSDs for Honda trannies, they did sometimes get stuck, but I THINK (key word) that was because of a dust shield problem. I think you had to remove the dust shield on your axels, or it WOULD get stuck. Apparently they came out with a sec. gen sorta, and fixed it though, because I havent heard of that lately.
I have seen a newer one installed into a civ. tranny, and the dust shield/rings were NOT removed, and it worked just fine.
So thats my two cents.
There were a few posts on H-T about it also I think. try search.
EDIT: Option one is crap IMO. Its like the Phantom "LSD" its not really an LSD, I cant remember how it works exactly, but its not true LSD. I think it just holds the axels together in the center hole, but the old phantoms broke alot (from what ive heard)
Option 2 would be my choice, there are a few LSDs, I think helical is where both axels turn all the time? And there is another one, the Open differential that only turns the other when cornering.
Or maybe they are switched around. Anyone else have input on the different kinds of diffs?
Old Sep 8, 2006 | 09:16 AM
fireant's Avatar
Default Re: opinions about ebay LSD (aXhatch)
Search around in the rr/ax forums here and you'll see some archived threads that go for pages about the OBX units. By reading them you should be able to figure out what exactly to look for when inspecting your new one for potential problems.
I have a buddy who's been using one for quite a while on race-rubber with no problems yet.
Old Sep 8, 2006 | 09:26 AM
SiRay13's Avatar
you get what you pay for.
Old Sep 8, 2006 | 09:57 AM
zenon8890's Avatar
whats the different between obx lsd or quaife or cusco or original jdm ones?!
Old Sep 8, 2006 | 10:08 AM
CoreyR's Avatar
Default Re: (zenon8890)
i think the problem with the old ones is the groove where to locking rings on the axles sit so the axle cant pop out was not beveled so the clip would catch the edge and not allow the axle to come out. i think the new ones have a bevel on them now.
Old Sep 8, 2006 | 10:46 AM
si90rex's Avatar
Default Re: (CoreyR)
don't get an lsd off ebay. want other mods do u have to the suspension? strut bars, will help, traction bars, good tires, shocks, ect. lsd its all that great. sometimes once the tire brake its hard to get traction again. i have both a lsd and non lsd trannys for my b16 yes i like the lsd. but i can spin the tire all throught 2nd sometimes, and i'm feathering the gas the hole way. plus ebays cheap ****. unless u can find a name brand buy now thing.
Old Sep 8, 2006 | 02:09 PM
SiRay13's Avatar
the nice thing about quaife is that they have a life time warrenty, it's quality and it will hold up to high hp and tq.
Old Sep 8, 2006 | 02:16 PM
Tyson's Avatar
option 1 is not a proper or even effective LSD. its a copy of the phantom grip, which itself is an INCOMPLETE copy of another design. i wont go into what its missing, just dont do it.
option 2 the OBX diff has quality issues. some ppl reported bad things, some ppl reported fine success. when i hear both sides, theres an obvious quality issue. as its been said, its a copy of the quaife design. quaife knows their stuff about making a quality part (even if they get some measurements goofed like bearing size and pinion depth on the steering racks). i dont trust chinese made stuff that are copies of an outward design and didnt go thru the proper engineering and material strength considerations.
Old Sep 8, 2006 | 02:24 PM
zenon8890's Avatar
how much does quaife lsd
Old Sep 8, 2006 | 02:25 PM
xDicktonesx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aXhatch &raquo;</TD></TR><TR><TD CLASS="quote">OBX when they first came out with LSDs for Honda trannies, they did sometimes get stuck, but I THINK (key word) that was because of a dust shield problem. I think you had to remove the dust shield on your axels, or it WOULD get stuck. Apparently they came out with a sec. gen sorta, and fixed it though, because I havent heard of that lately.
Or maybe they are switched around. Anyone else have input on the different kinds of diffs?</TD></TR></TABLE>
this guy is partially right. here is the story. obx copied the quaife. the quiafe is a bad *** lsd. therefore the obx is just as bad ***. HOWEVER, the first obx lsds were not MACHINED on the splines. this means they grab the axles and they dont let them go. works great until you try to pull your axles. the issue has been resolved so, jsut loo kat it like gettign a quaife for half the price of a quiafe
gsxr1k05's Avatar
http://www.kingmotorsports.com
http://www.robearracing.com
http://www.sportcompactonly.com
try here for priced
zenon8890's Avatar
how much does quaife lsd cost?! and where can i buy it online?! the burn out problem i hve its really really serious and i'd like to get all the power i have to the ground not just wheel spinning! when the turbo starts to spool the car just burn burn burn
Old Sep 8, 2006 | 02:32 PM
"burnout problem"
great name for a band
Old Sep 8, 2006 | 02:41 PM
CoreyR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zenon8890 &raquo;</TD></TR><TR><TD CLASS="quote">how much does quaife lsd cost?! and where can i buy it online?! the burn out problem i hve its really really serious and i'd like to get all the power i have to the ground not just wheel spinning! when the turbo starts to spool the car just burn burn burn </TD></TR></TABLE>
quaifes are $900. LSD isnt going to eliminate your traction problems completely. any high horsepower FWD car with street tires is just going to spin. try some sticky tires like drag radials.
Old Sep 8, 2006 | 02:47 PM
Tyson's Avatar
Default Re: (xDEFTONESx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xDEFTONESx &raquo;</TD></TR><TR><TD CLASS="quote">"burnout problem"
great name for a band</TD></TR></TABLE>
so would deftones... oh wait...
Old Sep 8, 2006 | 02:50 PM
zenon8890's Avatar
i just bought perrili's 15" slicks with very light rims! i bought it second hand but they were used only ontime i guess they can eliminate the problem
Rooftop voter
Suspension & Brakes
Apr 6, 2007 07:53 PM
wespirl
Nov 2, 2004 10:15 PM
MintyDip
Jun 6, 2002 02:05 PM
