How to improve a/c
Old Sep 8, 2006 | 07:52 AM
Chef Andre's Avatar
HT's TOP CHEF
Default How to improve a/c
Got a quick question for you guys. I'm in hot sticky florida and during the day when the sun is out all the way I run my ac it feel like its hardly working. But when it's raining or at night the ac blows freezing cold. What can I do to improve th efficency of my ac unit? Thanks in advance guys.
Old Sep 8, 2006 | 07:59 AM
-Gary-'s Avatar
Default Re: How to improve a/c (Chef Andre)
Cleaning your condenser? You also might want to make sure your fan is working properly.
Old Sep 8, 2006 | 08:07 AM
schardbody's Avatar
get more air to the condensor which means : cleaning all the debri from around it, or a bigger fan.
Old Sep 8, 2006 | 08:29 AM
drktorn's Avatar
Default Re: (schardbody)
add another fan in the front
Old Sep 8, 2006 | 09:09 AM
Padawan's Avatar
Darth ModerVader
- Make sure the A/C system has been properly serviced
- Reduce underhood temperatures (coat exhaust manifold, etc.)
- Have a good, heat-rejecting film applied to windows
Old Sep 8, 2006 | 01:56 PM
killakoupe's Avatar
From: San Diego to Palm Springs Runnin Things, CA, USA
you can try recharging it with R134. not the best solution but quick and cheap and sometime is all you need.
Old Sep 8, 2006 | 09:31 PM
Chef Andre's Avatar
HT's TOP CHEF
Thanks for all the advice guys. The system has already ben retrofitted to r134 so I'll clean it down real good tommorrow and let you all know how it turns out.
Old Sep 8, 2006 | 09:44 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chef Andre &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for all the advice guys. The system has already ben retrofitted to r134 so I'll clean it down real good tommorrow and let you all know how it turns out. </TD></TR></TABLE>
i have the same problem. haven't quite found a solution. post back and let us know how it goes.
Old Sep 8, 2006 | 09:54 PM
james111's Avatar
Default Re: How to improve a/c (philosofy1)
change the drier and expansion valve out along with cleaning the condensor.....
Old Sep 9, 2006 | 01:56 AM
Junkiii Ek's Avatar
try recharging the freeon
9.3.S.I.L.U.D.E.
Jul 17, 2010 05:58 PM
Rooftop-Special
Jun 30, 2010 07:21 PM
stockEJ
Aug 8, 2008 07:50 AM
playahwitgame
Jun 20, 2006 04:40 PM
