ignition timing question
will running a 18 timing which is within factory specs ALWAYS be better than stock 16? i mean is it guaranteed extra power down below and even more with tuning?
what do you guys run on a bone stock itr?
It really depends on the application/compression ratio/ecu etc.
There is no real answer to your question.
The ideal solution is to sync your distributor to your engine management's (ecu) ignition tables & tune the car via the management system's adjustable ignition tables etc.
hmtcrxsir
Apr 3, 2017 05:53 AM
elprovos
Engine Management and Tuning
Feb 10, 2011 10:35 AM
jdmb16ef8
10
May 4, 2008 04:47 AM
TauMax
Mar 21, 2005 07:42 PM
