B20 Block for $100 bucks
Well if you have full access to the engine, check for any cracks in the cylinder walls and inspect all rod bearings and crank journals.
If possible plastigauge each main and rod bearing that is still good and check to see what the specs are on the bearings.
other then that you'd have to send it to a machine shop for further inspection and get a the block hot tanked and honed
lucas569
Aug 12, 2002 10:22 AM
