B16 Swap + ECU
Old Sep 7, 2006 | 07:42 PM
B16SolMan's Avatar
New User
Default B16 Swap + ECU
Can I use the P28 with the B16 I am getting? I have it now in my mini/me and I know that it can be wired with VTEC but do I have to worry about a Hondata or OBD or anything like that? Would it just be better to get the wiring harness and a P30 or some other ECU?
Old Sep 7, 2006 | 07:48 PM
nsxmatt's Avatar
Default Re: B16 Swap + ECU (B16SolMan)
What??
B16 uses a P30. Other than that I have no clue what you don't understand.
Old Sep 7, 2006 | 08:23 PM
ntrider's Avatar
Default Re: B16 Swap + ECU (nsxmatt)
I believe the b16 is obd2 specifically obd2b. so you would need a obd2b-->obd1 (p28) wire conversion harness. hopefully someone will correct me if I am wrong.
Old Sep 7, 2006 | 10:34 PM
EGwhat!!!'s Avatar
yes you can use the p28 but you would have to get it chipped
Old Sep 8, 2006 | 06:15 AM
B16SolMan's Avatar
New User
So it would definetely be better and easier to just get a P30 and wiring harness. Thanks
Old Sep 8, 2006 | 06:18 AM
deckster333's Avatar
Default Re: (B16SolMan)
you can use your stock obd1 harness and p28 ecu, just get it chipped very simple
Old Sep 8, 2006 | 06:46 AM
SkoundrelUSA's Avatar
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16SolMan &raquo;</TD></TR><TR><TD CLASS="quote">Can I use the P28 with the B16 I am getting? I have it now in my mini/me and I know that it can be wired with VTEC but do I have to worry about a Hondata or OBD or anything like that? Would it just be better to get the wiring harness and a P30 or some other ECU?</TD></TR></TABLE>
How bout telling us what model car you have and what year engine you have?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ntrider &raquo;</TD></TR><TR><TD CLASS="quote">I believe the b16 is obd2 specifically obd2b. so you would need a obd2b--&gt;obd1 (p28) wire conversion harness. hopefully someone will correct me if I am wrong.</TD></TR></TABLE>
Ever hear of a Del Sol VTEC or Civic SIR II? OBD1 meng
:::SIRll_EJ1:::
Feb 19, 2010 05:27 PM
04silvep3
Sep 7, 2008 06:48 AM
category5 SI
Feb 20, 2008 07:57 PM
JDMProjektSi
Feb 19, 2004 08:34 AM
PY01ITR42
Aug 21, 2002 08:10 AM
