Few Questions: 94 LS into 92 hatch
Old Sep 7, 2006 | 07:31 PM
accordheat's Avatar
Default Few Questions: 94 LS into 92 hatch
I've read the stickies, searched, done alot of stuff. Just want some answers.
I have all of the LS mounts. Do I need others/different ones?
What radiator do I use? I currently dont have one on the shell.
Will aftermarket header and intake fit under the hood O.K.?
Any help is appreciated. Thanks.
Old Sep 7, 2006 | 07:35 PM
fucjdm
Guest
Posts: n/a
Default Re: Few Questions: 94 LS into 92 hatch (accordheat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordheat &raquo;</TD></TR><TR><TD CLASS="quote">I've read the stickies, searched, done alot of stuff. Just want some answers.
</TD></TR></TABLE> All the mounts fit. You can use your stock eg radiator. and yes header and intake all fit ok...
Old Sep 7, 2006 | 07:45 PM
accordheat's Avatar
Default Re: Few Questions: 94 LS into 92 hatch (chillis)
thanks for the quick response
I currently do not have a radiator and was just thinking about aftermarket ones. (Fluidyne for example) Any big benefit to one of those? If not, ill just pick up an EG rad.
Old Sep 10, 2006 | 04:15 PM
accordheat's Avatar
anyone?
Old Sep 11, 2006 | 06:09 AM
jays93eg6's Avatar
A stock EG radiator will work fine. The aftermarket ones are good, but unless you have boost plans in the future the stock one will work with no problems. I am running a stock civic radiator with my C1 swap. Hope this helps.
Old Sep 11, 2006 | 06:47 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: Few Questions: 94 LS into 92 hatch (jays93eg6)
Stick with the stock Rad bro. It'll all be good.
Old Sep 11, 2006 | 06:51 AM
crawlin's Avatar
Default Re: Few Questions: 94 LS into 92 hatch (ek forever guy)
or you could always go get a cheaper aftermarket radiator for like a little bit under 100$ to your door and not have to deal with buying someone's used radiator
TeggerLS
Sep 13, 2006 03:38 PM
IntegR
May 24, 2006 06:43 PM
vtechrex
Feb 2, 2006 10:49 PM
JDM2ndGen
Mar 11, 2004 01:23 PM
KoRE
Nov 9, 2002 01:21 PM
