sun roof won't open can anyone troubleshoot?
Guest
Posts: n/a
has your car been sitting a long time without opening the sunroof? Cause if it has I had this issue with my 00 Si and I had to slightly pry it open.... It was sealed to the body... Cleaned it and lubed..... Works like a charm now.... Other wise if not I know they have a manual opening bolt... not sure on location
If that doesn't work pull the headliner down in the front. This will give you access to the motor assembly. There is a clutch mech with a nut and a washer bent up to keep the nut from backing off. flatten the washer and use the manual crank in the car tool kit. if you don't have it find the right size allen key, use a wrench to tighten the nut until you get the sun roof working right again. It shouldn't take to much pressure to make it work right. Make sure to bend the lock washer back when you are done
Snafu-Si
11
Aug 3, 2002 05:48 PM
