car wont start
did it spark??
all you need to do is touch it to metal, you dont need a screwdriver to do it....
honestly i doubt that could have done anything to the dizzy, but who knows, those things are funky as hell....
first, check make sure your battery is at the good state of charge. being 12v +.
if you have a external ignition coil, check for spark there. if there isnt spark there and no spark at the plugs, it would be your ignitor.
and make sure your ECU isnt burnt or bad.
Battery>>>
-Ignitor
-ECU
-Ignition coil
all 3 of these must work to make spark. good luck!
Battery>>>
-Ignitor
-ECU
-Ignition coil
andrew714
Dec 13, 2007 09:35 PM
s2kkk
20
Apr 15, 2004 11:12 AM
