= H23a1 A/C system removal? Belt question.
Old Sep 7, 2006 | 05:47 PM
preludebbduce
Guest
Posts: n/a
Default = H23a1 A/C system removal? Belt question.
Howdy guys,
I have 93' Si with a h23a1 and my A/C compressor is out. Don't want to waste money replacing it. So im deciding to just take out the Entire...A/C system. (weight reduction and some power gain) i figure.
Compressor, Lines, Condensor.The problem : the A/C belt is also runnning the Alternator.I want to cut the a/c belt but then the Alternator wouldn't get power.
What size belt Should I buy that will run from Crank to Alternator bypassing A/C compressor?
Thanks.
Old Sep 7, 2006 | 08:25 PM
pprowler6's Avatar
Default Re: = H23a1 A/C system removal? Belt question. (preludebbduce)
just get a belt from a prelude that didnt come with air conditioning i think it was the "s" model
Old Sep 7, 2006 | 08:40 PM
98vtec's Avatar
moderator emeritus
Default Re: = H23a1 A/C system removal? Belt question. (pprowler6)
i got a string and used it to measure an approximate length from the alternator to the crank pulley. Then went to autozone and picked 3 belts that could work. Kept the one that fit right and returned the other two. On my h22, it was 37".
Old Sep 7, 2006 | 08:43 PM
M2B4's Avatar
Default Re: = H23a1 A/C system removal? Belt question. (98vtec)
when i was at autozone here they had a belt on file for no ac in stock just tell em thats what you want. b/c the "s" in 92-93 had optional a/c i believe
Old Sep 8, 2006 | 04:17 AM
flyrod's Avatar
Default Re: = H23a1 A/C system removal? Belt question. (M2B4)
370K5
Old Sep 8, 2006 | 01:14 PM
prelude_h22vtec's Avatar
this question has been asked 2309847349083 times!!! but yeah i did the string thing too and it worked great for me
Old Sep 8, 2006 | 03:46 PM
preludebbduce
Guest
Posts: n/a
so the F22 belt is the same as the H23? Right?
Old Sep 8, 2006 | 03:51 PM
preludebbduce
Guest
Posts: n/a
Default Re: (prelude_h22vtec)
It was probably Been asked a lot. BUT I Searched and couldn't find anything on this. SO i thought I'd ask.
Thanks for your non help. and Other people. Thanks! i'll go to autozone...do a String...measurement !
Peace!
My homedepot made UPPER Strut and HFP intake. Sporting My own Brand: Driven Under Creative Engineering
made of PURE STEEL. strut bar COST: Under $20 bucks
aluminum custom HFP intake: $12 bucks.
Let me know what you think. FORD 500 degree Blue / block paint from (Autozone)
Modified by preludebbduce at 5:03 PM 9/8/2006
Old Sep 9, 2006 | 11:35 AM
Silver Surfer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pprowler6 &raquo;</TD></TR><TR><TD CLASS="quote">just get a belt from a prelude that didnt come with air conditioning i think it was the "s" model</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2B4 &raquo;</TD></TR><TR><TD CLASS="quote">when i was at autozone here they had a belt on file for no ac in stock just tell em thats what you want. b/c the "s" in 92-93 had optional a/c i believe</TD></TR></TABLE>
THAT IS NOT THE BELT YOU WANT
the lenght and width of that belt are both wrong.....i'm pretty sure i posted this in one of the other threads
i'm pretty sure it was 37" like they said, and you also need to know the number of ribs across the old belt, or you could just bring it in and show them
texx72
Nov 22, 2009 03:05 PM
hpsi93
Aug 26, 2007 02:47 AM
efyou
Aug 12, 2007 07:40 PM
turbociv910
Jan 25, 2007 07:01 PM
93lxh22
Dec 31, 2006 01:24 PM
