slave cylinder?
Old Sep 7, 2006 | 02:57 PM
puertoroc7976's Avatar
Default slave cylinder?
well i recently had my clutch replaced and now something is squeaking when i leave my car in nuetral i found out that where my slave cylinder is its coming from their but when i put my foot slightly on the clutch pedal it stops someone said i needed to adjust something in my clutch or is it the slave cylinder causing this plz help
Old Sep 7, 2006 | 03:06 PM
unknown0001's Avatar
Default Re: slave cylinder? (puertoroc7976)
The slave cylinder allows the clutch lines to be presurized and allows you to bleed the system if there is air in the lines.
If your hearing a squeek then your clutch pedal might be sitting too loose. There is a nut under the pedal that you can adjust the distance of the clutch pedal... so try to adjust that and see if the noise goes away
PaulMc
May 18, 2014 05:04 PM
RDAYA0
Dec 14, 2006 05:31 PM
FuNkDrSpOt
Oct 10, 2006 09:48 PM
g00se
Mar 8, 2004 06:11 PM
