205/40/17 5th gen Lude
Old Sep 7, 2006 | 02:42 PM
ej2_sir's Avatar
Default 205/40/17 5th gen Lude
Looking at getting 7x17 42 offset with the fore mentioned tyre size for my 98 Pelude VTI 4ws. Any problems to mention with fitment with a 30mm drop?
thanks
Old Sep 7, 2006 | 02:56 PM
v4lu3s's Avatar
RTFM
i persoanlyl would recommend a bit more rubber, i would go 215/45/17 or at least 205/45/17, the 205/40 is to me just not enough rubber for a lude or accord.
Old Sep 7, 2006 | 03:02 PM
ej2_sir's Avatar
Default Re: (v4lu3s)
whats the downside in your opinion? harsh ride and wheel hop? will the clearances be ok with this package?
Thanks
Old Sep 7, 2006 | 04:21 PM
BlueLude 94's Avatar
Default Re: (ej2_sir)
215/40/17 would be better imo. Thats what i have on my gram lights and its perfect.
Old Sep 7, 2006 | 08:35 PM
BB6racer's Avatar
205/40 will work, but this will cause your wheels' overall diameter to shrink a little. this will result in smaller sidewalls (which is bad if the tire's don't have a stiff enough sidewall), your gear ratios will slightly change and your revs will be higher, your car will lower slightly, your tires will wear through faster, your speedometer will be off a little, etc...
but smaller tires will also improve acceleration, and like i said before your revs will be higher, and your revs will not drop as much between shifts.
i would still recommend the correct tire size though for a daily driver prelude. i use 215/40-17 on my 17" x 7" rims.
Old Sep 7, 2006 | 10:22 PM
lYellowDragonl's Avatar
215/40/17 for the win!
Old Sep 7, 2006 | 10:29 PM
MadCityLude
Guest
Posts: n/a
Default Re: (lYellowDragonl)
How bout a 225 40 17? Bigger paw means better traction
Old Sep 8, 2006 | 02:06 AM
ej2_sir's Avatar
Default Re: (MadCityLude)
How will these tyre size effect the fitment? (7x17 42 offset) any issues with rubbing or arch clearance with a 30mm drop?
Thanks for the suggestions so far
Old Sep 8, 2006 | 09:48 AM
Slvrwnd's Avatar
I am dropped 2in on skunk2. with 205/40/17 with a 45+ offset and i dont rub at all. But yes your revs are higher and the speedo will be off as mentioned by BB6racer
Old Sep 9, 2006 | 05:44 PM
my9thtry's Avatar
Default Re: (Slvrwnd)
i run 225/45/17's with no issues i would not run a 40 profile tire on a lude. espcially a 5th gen it will look horrible
Old Sep 10, 2006 | 08:50 PM
nonvteclude's Avatar
hey guys sorry to thread jack but what is the best size to use on a 16 rim on a 4th gen. meaning stock diameter and a good sidewall
Old Sep 11, 2006 | 08:04 AM
HxClude's Avatar
Default Re: 205/40/17 5th gen Lude (ej2_sir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej2_sir &raquo;</TD></TR><TR><TD CLASS="quote">Looking at getting 7x17 42 offset with the fore mentioned tyre size for my 98 Pelude VTI 4ws. Any problems to mention with fitment with a 30mm drop?
thanks</TD></TR></TABLE>
205/40/17 is smaller than the stock wheel diameter. 205/45/17 or 215/40/17 are better. 215/40/17 is only slightly smaller than stock diameter and gives you a little more treadwidth.
check the load ratings on the 205/40/17s too - I bet that 99% of the tires out there in that size don't meet the factory load rating if you're going to stray more than a few percent from the factory size, you'd be safer to go bigger (215/45/17 for example).
leemikemphstn
Sep 6, 2007 07:51 AM
MNsnowdaboy
Aug 11, 2006 07:27 PM
Accord98
May 22, 2003 10:59 AM
lodown414
Nov 4, 2002 10:11 PM
SuperRice
Mar 5, 2002 09:18 AM
