Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
SPC or skunk 2? camber kit
Old Sep 7, 2006 | 02:07 PM
nello a.'s Avatar
Default camber kit/ NEW QUESTIONS
1995 del sol vtec. car is only used for autox and driving to the event. keep in mind the drive is sometimes over 2 hrs. i would like to have something easily adjustable(skunk 2 pro series). everyone recommends spc-this type looks like a pain in the *** to adjust. opinions on any other brands would be appreciated. i need something for the front right now. i did the washer trick on the rear to get the camber to -1.2 both sides.
Modified by nello a. at 3:25 PM 9/7/2006
sorry to bring this up again. thanks to those who have helped so far.
Skunk sells the pro series with new poly bushings for another 20.00. You cannot purchase the bushings from honda seperately-you must spend 130.00 per side, and get the whole arm assembly. Any problems with these bushings? Does someone else sell just uca "bolts" with the bushings. Anyone have pics of the SPC uca-their site is all part numbers (or did i miss something?). Do they come with the bushings? They should for 375.00.
Modified by nello a. at 3:38 PM 9/15/2006
Modified by nello a. at 12:27 PM 9/19/2006
Old Sep 7, 2006 | 02:54 PM
TunerN00b's Avatar
Default Re: SPC or skunk 2? camber kit (nello a.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nello a. &raquo;</TD></TR><TR><TD CLASS="quote">1995 del sol vtec. car is only used for autox and driving to the event. keep in mind the drive is sometimes over 2 hrs. i would like to have something easily adjustable(skunk 2 pro series). everyone recommends spc-this type looks like a pain in the *** to adjust. opinions on any other brands would be appreciated. i need something for the front right now. i did the washer trick on the rear to get the camber to -1.2 both sides.
Modified by nello a. at 3:25 PM 9/7/2006</TD></TR></TABLE>
If its an autocross car, why would you remove camber?
I'm using SPC UCAs in the front, and its got to be easier to adjust than the skunk2 units, its a single huge nut instead of 4 tiny ones. Not that I know either way, since I don't have an alignment rack, the shop adjusts it for me when they align the car.
Old Sep 7, 2006 | 02:57 PM
nello a.'s Avatar
i want more negative camber in the front. i dont think spc makes a uca for del sols or 92-95 civics? someone correct me if i am wrong.
Old Sep 8, 2006 | 12:56 AM
nello a.'s Avatar
guess i should have asked about formula 1 or oil changes? body kits?
Old Sep 8, 2006 | 06:53 AM
bad-monkey's Avatar
get the skank2. the ball joints or offset bushings have clearance issues, though, i guess the offset bushings won't have clearance issues unless you're adding pos. camber.
the skank 2 is lower profile and alot of people use them, even if the company tends to suck.
Old Sep 8, 2006 | 09:31 AM
Jack Black's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nello a. &raquo;</TD></TR><TR><TD CLASS="quote">guess i should have asked about formula 1 or oil changes? body kits?</TD></TR></TABLE>
The guy at the tire place today asked me if I had any neon *shudder*
I use the Omni front upper arms, which are the same as the old-style Skunk2 arms. They work fine for me, but I treat my car fairly gently. The whole arm style seems like it's a lot easier to adjust than the ball joints (like SPC) and as monkey pointed out, they don't take up as much room, either.
For other options, search archived topics in this forum for "camber". It's a topic that's been covered a lot.
Old Sep 8, 2006 | 03:39 PM
nello a.'s Avatar
i did search by the way. i want as much info. as possible. thanks
Old Sep 8, 2006 | 04:02 PM
coneheadsracing's Avatar
Default Re: (nello a.)
I like my skunk setup. I switched my four bolts out to regular bolts, they come with alan's, too easy to strip, as it use to see snow, and wonderful michigan over salting procedures. The original ball joints went out in a hurry. The replacements i bought have lasted fine, i should mention, that went out was the boot's. The actual joint was fine, no slop. I do tend to rub on my inner fenders with them, but nothing serious.... for me. I have no experience with the other ones you mentioned, so sorry can't help ya.
Old Sep 10, 2006 | 03:40 AM
vbspec's Avatar
I assume you are talking about the front kit? I would recomend neither, and just face the fact if you daily drive the car the front tires will wear out sooner. But heres why. Both kits are going to cause you problems. The SPC kit replaces the ball joint, the new one is much taller than the OEM one. This will elevate the outside of the upper control arm, from the spindle. The upper control arm will then wind up hitting the inside of the fender when the suspension is compressed; not good. As for the Skunk2 setup this style also will raise the outside of the upper control arm and IMO 4 little bolts are not something that I would trust to keep tight, and not slip.
Also if you are going to be playing with your camber you will also have to adjust your toe setting too...... every time or you will wear out your tires and then you are back to square one.
Old Sep 10, 2006 | 05:52 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nello a. &raquo;</TD></TR><TR><TD CLASS="quote">i want more negative camber in the front. i dont think spc makes a uca for del sols or 92-95 civics? someone correct me if i am wrong.</TD></TR></TABLE>
92-95 Civic front suspension is the same as 94-01 Integra.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vbspec &raquo;</TD></TR><TR><TD CLASS="quote">I assume you are talking about the front kit? I would recomend neither, and just face the fact if you daily drive the car the front tires will wear out sooner. But heres why. Both kits are going to cause you problems. The SPC kit replaces the ball joint, the new one is much taller than the OEM one. This will elevate the outside of the upper control arm, from the spindle. The upper control arm will then wind up hitting the inside of the fender when the suspension is compressed; not good. As for the Skunk2 setup this style also will raise the outside of the upper control arm and IMO 4 little bolts are not something that I would trust to keep tight, and not slip.
Also if you are going to be playing with your camber you will also have to adjust your toe setting too...... every time or you will wear out your tires and then you are back to square one. </TD></TR></TABLE>
SPC has 2 different ways to adjust camber on the 92-95 Civic / 94-01 Integra. They do have offset balljoints, and they also have complete UCAs with a sliding plate. Both will push the UCA up higher than stock, and both will reduce suspension clearance. I'm using the SPC UCAs, and they do seem to have a little more clearance than the skunk2 units, because of their thinness and curved shape.
Old Sep 10, 2006 | 11:46 PM
nello a.'s Avatar
you sure about 94-01 integra ucas working on 92-95 civics? i have heard other parts are the same or compatible. second opinion anyone?
Old Sep 11, 2006 | 06:09 PM
b18ccivics's Avatar
i have the skunk 2 but if i was to buy again i would get the spc, at the time skunk2 was all i could afford, and spc quality is top notch and to can adjust caster
Old Sep 12, 2006 | 08:43 PM
instrument's Avatar
this is common knowledge.
Old Sep 15, 2006 | 02:40 PM
nello a.'s Avatar
new questions at top. thanks to those that gave advice.
Old Sep 15, 2006 | 04:22 PM
TunerN00b's Avatar
Default Re: SPC or skunk 2? camber kit / NEW QUESTIONS (nello a.)
I had poly bushings in an Ingalls camber kit before I switched to the SPC UCAs. Aside from squeeking, and lots of it, over every bump, after the install grease washed out in 2 weeks, they seemed fine. I've heard many complain about poly though, since it seems to deform over time. Mine still look new, but they were on the car for less than 4 months before I got sick of them.
Modified by nello a. at 3:38 PM 9/15/2006</TD></TR></TABLE>
Old Sep 15, 2006 | 07:08 PM
b18ccivics's Avatar
Default Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument &raquo;</TD></TR><TR><TD CLASS="quote">you sure about 94-01 integra ucas working on 92-95 civics? i have heard other parts are the same or compatible. second opinion anyone?
this is common knowledge.</TD></TR></TABLE>
yes they are the same
Old Sep 16, 2006 | 01:04 AM
Outrun's Avatar
Default Re: (b18ccivics)
Here's pics of the anchor bolts. I have them on my Civic and have been satisfied for the past 5-6 years I've had them.
Old Sep 19, 2006 | 01:32 AM
nello a.'s Avatar
anyone? where can you get these anchor bolt bushings besides honda, skunk, or somebody like energy suspension? somebody pass on the info.,please. the search helps not.
Modified by nello a. at 6:35 PM 9/19/2006
Hatcheys314
Apr 12, 2011 10:06 AM
[Rush]
10
May 5, 2010 10:52 AM
RED_90TEG
Suspension & Brakes
May 20, 2007 11:25 AM
JoeDaSoto
Suspension & Brakes
Feb 27, 2007 01:04 PM
chrisbell37
15
Jul 30, 2006 02:40 PM
