what ecu is for a 96 integra gsr
is it usdm gsr? if so it would be b18c1, if is just b18c only, it can jdm gsr/type r
so find out which motor is it
you have to choice, p73 is for a type r and p72 is for a gsr
The B18C should be the JDM SiR, which is similar to the USDM B18C1 GSR engine. You should get a P72 in that case to control the IAB in the dual stage intake manifold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">The B18C should be the JDM SiR, which is similar to the USDM B18C1 GSR engine. You should get a P72 in that case to control the IAB in the dual stage intake manifold.</TD></TR></TABLE>
is also could be a jdm type r
the OBD2 reader probably could not read, that is why no connection was made
what ecu do you have in it right now?
you will need an obd2a P72 ecu to go along with your swap
95integragsr1984
12
May 30, 2003 12:22 AM
