"E-Brake Light is always on" I need help!
Old Sep 7, 2006 | 10:58 AM
LunchboxZT's Avatar
Default "E-Brake Light is always on" I need help!
My E-brake light stays on almost all the time, anyone else have this problem? Anyone know how to fix it?
Old Sep 7, 2006 | 10:59 AM
Trellis's Avatar
Default Re: "E-Brake Light is always on" I need help! (LunchboxZT)
me too...all though i noticed mine only does it when its cold outside.
Old Sep 7, 2006 | 11:01 AM
cjames235's Avatar
Default Re: "E-Brake Light is always on" I need help! (Trellis)
check your brake fluid the light comes on when your fluid is low......... temperature will make it expand and contract, which is why its on when cold
Old Sep 7, 2006 | 11:04 AM
The Tech-1's Avatar
Default Re: "E-Brake Light is always on" I need help! (cjames235)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjames235 &raquo;</TD></TR><TR><TD CLASS="quote">check your brake fluid the light comes on when your fluid is low......... temperature will make it expand and contract, which is why its on when cold</TD></TR></TABLE>
Exaclty just fill your brake fluid resevoir up to the top and the light will turn off.
Old Sep 7, 2006 | 11:16 AM
Chris N's Avatar
Check brake fluid level.
Old Sep 7, 2006 | 11:23 AM
Dave_B's Avatar
Common issue in the cold/winter. Mine used to do it. Check fluid level in the res and jiggle the float
Old Sep 7, 2006 | 11:25 AM
330R's Avatar
There is actually a TSB about this issue. Read here: http://www.team-integra.net/fo...earch
Old Sep 7, 2006 | 11:31 AM
a1320addict's Avatar
Default Re: "E-Brake Light is always on" I need help! (330R)
I had the same problem. Pull off the center console and check the wiring connection, it's sort of a quick-connect deal, make sure it's nice and snug.
Old Sep 7, 2006 | 11:45 AM
BLacK FirE's Avatar
Default Re: "E-Brake Light is always on" I need help! (a1320addict)
I had the same problem too during the cold, then all of a sudden last week it started up again. Searching here on HT I found it was a common problem and easily fixed by taking the cap off and putting it back on, unless your low on fluid then that's the solution.
Old Sep 7, 2006 | 02:32 PM
LunchboxZT's Avatar
Default Re: "E-Brake Light is always on" I need help! (BLacK FirE)
Weird, fluid levels looked OK, but after checking the fluid I turned the car on and voila, no brake light - weird.
Old Sep 7, 2006 | 03:02 PM
integ22's Avatar
Same thing happened to my brake light. It's the float inside the reservoir. Just take off the cap and move the float up/down and lube it up with brake fluid. HTH
Old Sep 8, 2006 | 04:56 AM
The Tech-1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LunchboxZT &raquo;</TD></TR><TR><TD CLASS="quote">Weird, fluid levels looked OK, but after checking the fluid I turned the car on and voila, no brake light - weird.
Most likely the level could look ok just top it off, and your problem will probably never come back.
I remember checking mine and the fluid was close to the max line. The light kept turning on every so often until i topped it off.
Old Sep 8, 2006 | 05:25 AM
KetteringITR's Avatar
Default Re: "E-Brake Light is always on" I need help! (The Tech-1)
Hey Bryan, good to see you finally made it over to Honda-Tech.
I have the same prob on mine but i jus usually ignore it and it goes off after a few minutes of driving. Ive been keeping an eye on my brake fluid for a good 9 months now (cuz this past winter was the first time i noticed it and then it stopped during the summer and has started to come on again now) and the level is right in the middle. The sensor in the brake resivoir apparently gets dirty and then throws the idiot light at you.
Old Sep 8, 2006 | 06:15 AM
topdog's Avatar
Default Re: "E-Brake Light is always on" I need help! (KetteringITR)
dont own a r but do work at honda....check the screen in the resivor see is it has a notch on the top side rim..if not replace it with a update one and a new cap..common problem with all honda...
Old Sep 8, 2006 | 06:18 AM
The Tech-1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KetteringITR &raquo;</TD></TR><TR><TD CLASS="quote">Hey Bryan, good to see you finally made it over to Honda-Tech.
I have the same prob on mine but i jus usually ignore it and it goes off after a few minutes of driving. Ive been keeping an eye on my brake fluid for a good 9 months now (cuz this past winter was the first time i noticed it and then it stopped during the summer and has started to come on again now) and the level is right in the middle. The sensor in the brake resivoir apparently gets dirty and then throws the idiot light at you.</TD></TR></TABLE>
I believe it's actually because that sensor floats, if the sensor is not floating high enough there's not enough fluid in the resevoir.
Old Sep 8, 2006 | 08:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Tech-1 &raquo;</TD></TR><TR><TD CLASS="quote">
I believe it's actually because that sensor floats, if the sensor is not floating high enough there's not enough fluid in the resevoir.</TD></TR></TABLE>
Youre prolly right. Thanks for the correction.
&lt;--- *Goes out to check the floater in the brake fluid*
Old Sep 8, 2006 | 01:22 PM
LunchboxZT's Avatar
Yep it's fixed now, topped off the brake fluid to the absolute top and cleaned it, gave it a good jiggle and it hasn't come back on yet! Which is good because sometomes it would stay on all the time, other times it would only do it when it was cold, or durring fast cornering ^_^
Z7
10
Aug 6, 2006 01:17 PM
jowy
Mar 14, 2005 05:52 PM
Project91CRX
14
Apr 26, 2004 03:47 PM
LSintegra
Apr 13, 2004 08:01 AM
vtec-izm
Aug 26, 2003 11:53 AM
