Suspension & Brakes Theory, alignment, spring rates....
Quick omnipower suspension question.
Old Sep 7, 2006 | 10:51 AM
MR_Ek4's Avatar
Default Quick omnipower suspension question.
omni coilover suspension installed on ek, can i adjust the lowar collar still on fronts and backs ? ? and how ? ? also the suspension came with 4 washers what were these meant for ? rear tie rods ? Thanks
Old Sep 7, 2006 | 02:20 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Quick omnipower suspension question. (EM1_00MRBuilt)
To adjust simply:
- jack the car up
- of the three locking nuts break the lower most one loose with provided spanner
- spin the entire threaded shock body to adjust ride height
- tighten lock nut
- move on to next corner
Old Sep 7, 2006 | 06:10 PM
MR_Ek4's Avatar
Default Re: Quick omnipower suspension question. (94eg!)
K I got the fronts just the 14mm nut above the fork but for the rears i have to take the whole suspension out to adjust lowar collar.
I got another question. Is it best to have the lower collar at the lowest point and use the locking perches to adjust height up and down or have the spring sitting flush with upper mount and use lower collar to adjust height up and down? ? is there any performance losses? or chance of damaging strut ? i am really confused on this Thanks
Old Sep 8, 2006 | 07:22 AM
94eg!'s Avatar
#1 Super Guy
Loved
No no no...
The double locking spring perch should be up as high as you get it to go without compressing the spring at all. They should just hold the spring in place when the car is off the ground (at full droop). If the spring perch is too high, it will squeez the spring & make it impossible to spin the threaded shock body without taking everything apart.
To adjust ride height, you simply break loose the lowest "single" locking nut & spin the shock body itself. You don't have to disconnect the shock from the LCA, or break loose the double-locking spring perches. As long as there is no pressure (or "preload") on the spring, the threaded shock body should easily spin in & out of the lower mount while it's connected to the LCA (rear) or damper fork(front)...
Old Sep 8, 2006 | 10:18 AM
MR_Ek4's Avatar
Just what i needed
Old Sep 8, 2006 | 03:10 PM
MR_Ek4's Avatar
ah **** got another problem. After i adjust the shock body all the way in the lower collar how do i lower it from there ? ? i have the shock body as low as it will go and the car still sits fairly high. the rears are fine and have plenty of room to adjust but the front shock body wont go any lower. Help. . . Thanks
Old Sep 8, 2006 | 03:34 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1_00MRBuilt &raquo;</TD></TR><TR><TD CLASS="quote">ah **** got another problem. After i adjust the shock body all the way in the lower collar how do i lower it from there ? ? i have the shock body as low as it will go and the car still sits fairly high. the rears are fine and have plenty of room to adjust but the front shock body wont go any lower. Help. . . Thanks </TD></TR></TABLE>
Sounds like you'll have to start losing shock travel to go any lower. If you can't shorted the shock body further, you'll have to adjust with the lower spring perch, and just accept the shortened shock travel and springs that aren't preloaded at full droop.
Etorres325
Suspension & Brakes
Apr 28, 2010 02:03 PM
only_way_is_k
Oct 11, 2009 12:34 PM
Tippyman
Sep 2, 2006 01:24 PM
- Sim -
Dec 27, 2004 06:35 AM
TurboTeG4
Apr 24, 2004 06:23 PM
