I found this hose tucked under the rear crossmember
Old Sep 7, 2006 | 10:39 AM
philkehn's Avatar
Default I found this hose tucked under the rear crossmember
Well i found a little rubber hose tucked under my rear crossmember in the engine bay, its a thin piece, it comes out right below the charcoal canister on the firewall
Question being - Is this just a vent hose from the inside of the car or does this hook up to anything?
I searched around and looked at pics here and there and I couldnt come up with anything that you can even see the hose
Any help is well appreciated
Old Sep 7, 2006 | 10:42 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: I found this hose tucked under the rear crossmember (philkehn)
Condensation drain line for the a/c..
Old Sep 7, 2006 | 10:47 AM
philkehn's Avatar
Ok I dont have a/c nor did i take it out of the car, states why I didnt know
Thanks
Old Sep 7, 2006 | 08:58 PM
stevescivic's Avatar
Default Re: (philkehn)
yep A/C condensate drain.
Yes your car has a/c but someone probably took some parts out of it.
I can see in your pics that you still have the refrigerant lines in your car.
Old Sep 8, 2006 | 03:13 PM
philkehn's Avatar
Default Re: (stevescivic)
yea i knew it used to be there i took out the relays for it and all the leftover pipes er lines what ever you wanna call em
rhino_92
Dec 17, 2012 01:43 AM
BJIntegra
Dec 16, 2009 07:10 PM
RicharDC4
May 27, 2009 05:45 PM
GetawayInMoscow
Jul 25, 2007 08:09 PM
Nick97hatch
Dec 8, 2004 05:53 AM
