quick epoxy/alluminum question...
Old Sep 7, 2006 | 06:27 AM
turboH22Aakkord's Avatar
Default quick epoxy/alluminum question...
ok, i have front mount intercooler on my turbo setup of my accord which i assume is alluminum... the two tabs on each end of the tanks have broken off so all that is holding up the cooler is just the plumbing... i have not much welding skill let alone with aluminum... is there an epoxy or soemthing that any of you guys would recomend? i could take it somewhere and probably will, i was just curious though if there were any good and strong epoxys for this? thanks...
Old Sep 7, 2006 | 08:45 AM
ophdehEEEzy's Avatar
Default Re: quick epoxy/alluminum question... (turboH22Aakkord)
Try JB Weld.
Old Sep 7, 2006 | 09:15 AM
Default Re: quick epoxy/alluminum question... (ophdehEEEzy)
i thought about it.. but i really dont trust that stuff... i just figured there was some special stuff for alluminum.. i dunno...
Old Sep 7, 2006 | 09:26 AM
jb weld has held my oil return bung for almost a year and a half. it's also keeping my broken swaybar endlink together.
Old Sep 7, 2006 | 09:42 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ophdehEEEzy &raquo;</TD></TR><TR><TD CLASS="quote">jb weld has held my oil return bung for almost a year and a half. it's also keeping my broken swaybar endlink together.</TD></TR></TABLE>
good info... i know alot of peps that use it for the oil line.. the only thing i was concerned about is that... my car rides ruff.. realllly ruff and it broke the original welds on the intercooler ... do you think JB weld would hold up to this kind of pressure?
Old Sep 7, 2006 | 10:58 AM
Flashmn's Avatar
No, the vibration will most likely crack it off, as its not really welding, but gluing.
Get them welded from some decent strength material.
Old Sep 7, 2006 | 11:08 AM
Default Re: quick epoxy/alluminum question... (Flashmn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flashmn &raquo;</TD></TR><TR><TD CLASS="quote">No, the vibration will most likely crack it off, as its not really welding, but gluing.
Get them welded from some decent strength material. </TD></TR></TABLE>
yeah, ive JB welded stuff before thats why im avoiding it with this haha... i probably will just take it alll apart and get some braces and have someone local weld it up... do you think the heat from the welding process could ruin the intercooler in anyway?
Old Sep 10, 2006 | 12:49 PM
KFMRC's Avatar
Take it and have it fixed. Obviously it wasn't strong enough the first time or something wasn't mounted right. Do not try and jb weld or any other epoxy as it makes it very difficult to do the welding later which you will need to have done.
Bite the bullet and get it welded!!!! Preferably by someone who knows what they are doing.
Old Sep 10, 2006 | 02:29 PM
nfn15037's Avatar
Default Re: quick epoxy/alluminum question... (KFMRC)
How were the tabs broken off to begin with? Epoxy won't be any stronger than the weld that was there before.
Old Sep 11, 2006 | 07:34 AM
90DALS's Avatar
JB weld + sandwich plate it.
Old Sep 11, 2006 | 07:41 AM
90DALS's Avatar
Default Re: (90DALS)
basically you over lap two plates on the orginal mounting tab. then glue it. i did this on my friends tabs that broke as well. he has maybe 20k miles on them without them breaking.
Old Sep 11, 2006 | 08:43 AM
GPNY's Avatar
JB Weld didn't work for me...
You can try 3M DP190 epoxy, but for the price of the DP 190, you might as well have it welded...
Old Sep 11, 2006 | 09:18 PM
90DALS's Avatar
also, sand it up a bit. oils from hands, or engine oil will effect how JB weld attaches to the metal.
Old Sep 12, 2006 | 05:15 AM
jolt-tsp's Avatar
Probably only cost you a few bucks if you can find someone to weld it. Even a really crappy mig weld is going to be better than jb weld.
91tealhatch
Feb 19, 2008 08:03 AM
turboH22Aakkord
Sep 8, 2006 12:11 PM
osuperjohno
Mar 29, 2005 04:57 PM
brickonwheels
May 18, 2004 10:44 PM
makaveli284
Jun 9, 2003 10:45 AM
