best valves for skunk2 Pro camshafts!
hi,
i have some problems with my valves
i boughte skunk2 oversize 0.5 valves high comp. and later i boght a skunk2 pro 2+ camshafts but i cant use it with the old oversize valves
so i need help with best valves for my new camshafts
buy a skunk2 valves or something better u know???
and i have a daul springs and titanium retainers from skunk2
my engine b16a
thanks
my engine b16a
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mentasti »</TD></TR><TR><TD CLASS="quote">im using the stock civic type r valves</TD></TR></TABLE>
damm they hold up. i would suggest you change them out before you drop a valve and blow your motor. i wouldnt feel safe using ctr valvetrain revving to 9300rpms
im now trying to replace th pro 2 with the pro 1 cams
the pro 1 can used with oversize after so far search and talk with skunk2 so i hop i can replace it
any one know or hear some one used skunk2 pro camshafts?
I heard the pro1's are beefier than the original stage 2. Just look at the specs. But anyways civic type r valves are meant to rev thru 10k... If you bought the oversize valves you plan on having (costly) machine work done to the head- just makin sure you know.
jDMJeRk
Feb 9, 2004 01:00 PM
