Suspension & Brakes Theory, alignment, spring rates....
big steering wheel problem need advice
Old Sep 6, 2006 | 11:45 PM
b00stME's Avatar
Default big steering wheel problem need advice
hey guys i ran into a problem
the problem was my car steering wheel was off centered to the right and so my friend said he knew how to align it and said he would do it for me and so he did... he pulled the air bag off and remove the wheel OFF and align it stright again. then later i found out this was the wrong way of doing the steering wheel alignment from this fourm
i need advive on what to do next?
how will i get the steering wheel back to factory?
will a regular wheel alignment and steering wheelalignment fix this?
thanks
Old Sep 6, 2006 | 11:59 PM
byronl's Avatar
Default Re: big steering wheel problem need advice (b00stME)
i had that same problem, my steering wheel was off and that would make the wheels point straight. I got an alignment done and it fixed the problem, now the wheel is pointing straight.
Old Sep 7, 2006 | 07:52 AM
b00stME's Avatar
Default Re: big steering wheel problem need advice (byronl)
so it would be back to factory if i get an algnment? the steering wheel was pulled off and put back on to a different position
any help/advice would be great i want it done the right way thanks
Old Sep 7, 2006 | 08:51 AM
byronl's Avatar
if it's been pulled off and set to a different position won't help any. You're gonna have to pull the steering wheel back off and align it, the service manual will tell you how to do it.
Old Sep 7, 2006 | 10:48 AM
jolt-tsp's Avatar
Tell the alignment shop to align the car, and then straighten the steering wheel.
The last time I got an alignment, they straightened the wheel (moved counter-clockwise a tooth or two), then aligned the car. Now my steering wheel is a tooth or two too far counter-clockwise
Old Sep 7, 2006 | 02:22 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: big steering wheel problem need advice (jolt-tsp)
Step one - Get alignment
Step two - Re align steering wheel
Step three - Enjoy
Old Sep 7, 2006 | 06:02 PM
b00stME's Avatar
Default Re: big steering wheel problem need advice (94eg!)
sounds good thakns for the help guys
Old Sep 8, 2006 | 02:05 PM
Tyson's Avatar
repositioning the steering wheel was a stupid idea.
i hope you got your alignment done. theyll be able to recenter your steering wheel properly now that you messed it up.
Dezso3
Honda Civic (2006 - 2015)
Dec 11, 2015 08:57 AM
teg_dc2
Mar 13, 2009 12:35 PM
OneFire
May 6, 2005 12:52 PM
b e e
Nov 19, 2004 11:04 PM
