d16z6 compression ???
just had a turbo put on - noticed after that had oil blow by , some one though i blew rings on the piston. I wasnt ripping.bagging on the car cuz waiting to get tuned with chrome up here. cyclinders 2 3 & 4 came up at about 125 .. and then # 1 hit 220 .. someth
ing honestly wrecked or what? car wont start now :S !!!
There should be a 10psi (ish) difference between all cylinders on a compression test. Also did you check your compression before you put the turbo in? Not tuning the car and driving it for awhile will definately cause something bad.
Modified by B18bEG6ick at 5:24 AM 9/7/2006
Did you hook up the Positive Crank Ventilation correctly? If you left it stock that what turn manifold gage pressure from vacuum to boost and it would no longer work at all, causing blow by.
What do you mean car won't start? What was the compression before turbo?
92BlackSi
17
Apr 10, 2005 07:30 PM
