JDM ITR headlight cleaning
Old Sep 6, 2006 | 10:05 PM
ejwan's Avatar
Default JDM ITR headlight cleaning
I've search and found no information about this issue. Don't know where to really post it here or the appearance/cosmetic form. With that being said, I am wondering how u guys cleaned the yellow buildup on the plastic lenses. I see threads that say to use Never Dull to wet sanding then buffing it out, but since the itr lenses are see through unlike the eg/ef/da headlights, will u be able to see the scratches after its all done. Also what is the best method of doing this process thanks.
Old Sep 6, 2006 | 10:14 PM
SYTFU Tommy.'s Avatar
Default Re: JDM ITR headlight cleaning (ejwan)
with a buffer, you can take out all the scratchs. all you need a good compund and know wat you are doing is all it takes. i did this to mines to get rid of couple of deep sractchs
Old Sep 6, 2006 | 10:56 PM
Kavehman's Avatar
Poorboys pro polish, or poorboys SSR1.
Get that and a buffer
Old Sep 7, 2006 | 07:11 AM
ejwan's Avatar
Default Re: (Kavehman)
Thanks for the replys guys anyone else have a better way of doing this
Old Sep 8, 2006 | 08:27 PM
JDMilanoRed's Avatar
Default Re: (ejwan)
if they're really bad or you dont feel like buffing for hours, get some 2000 grit paper and wetsand with soapy water... then buff with a compound that takes out scratches 2000 grit or lower... then buff with a polishing compound, then move on to some sort of swirl-remover... PERFECT headlights!
Old Sep 8, 2006 | 09:11 PM
floatfisher's Avatar
if your not dealing with scratches then apply never dull and buff off with a microfiber cloth
it will shine and look new
it works for me
Old Sep 8, 2006 | 09:29 PM
ejwan's Avatar
Default Re: (floatfisher)
no i'm not dealing with scratches the lense is yellow faded just like anyother plastic headlight lense
Old Sep 8, 2006 | 09:32 PM
Default Re: (ejwan)
then no need for the paper... use a light-cutting rubbing compound, then polish, then swirl-remove...
Old Sep 9, 2006 | 07:09 AM
AntonioH's Avatar
I have the same problem. I just buff it out every once in awhile.
whyS0serious
Jun 6, 2019 05:26 PM
whyS0serious
Lighting
Apr 19, 2018 10:50 AM
01_ITR
Nov 9, 2008 03:59 PM
SunnyTO
Paint and Body
Mar 16, 2008 01:47 PM
1999CivicSi
Dec 1, 2006 02:31 PM
