another obd0 - obd1 with a twist question...little help.
Old Sep 6, 2006 | 09:01 PM
nitroracer's Avatar
Default another obd0 - obd1 with a twist question...little help.
car: 88 dx crx
so ive been doing the big search and still no luck on where to start. i have 98(b18b) motor w/ harness and trying to put it in a dx crx. where do i start guys? should i get rid of the obd2 harness and get a obd1? can i use the obd2 harness and use obd2-1 harness to ecu? or just run the dx harness modified?
Old Sep 6, 2006 | 09:05 PM
nitroracer's Avatar
Default Re: another obd0 - obd1 with a twist question...little help. (nitroracer)
maken it all complicated for myself. point me in the right direction.
i want to run obd1 ecu w/ obd2 engine harness in a 88 dx crx? yes ive seached! i hope that explains alittle better
Old Sep 7, 2006 | 10:47 AM
APEX CRX's Avatar
Modify your stock harness and convert to Multi-point
Old Sep 7, 2006 | 08:15 PM
nitroracer's Avatar
Default Re: another obd0 - obd1 with a twist question...little help. (APEX CRX)
k theres that way, what other ways can i go about
Old Sep 7, 2006 | 08:57 PM
TheCheeseWedge's Avatar
replace you whole dash harness with that of an obd1
are you trying to bar certify your car or is there any other reason you want obd1?
if not then what you would do is keep it obd0 use your stock harness, convert to multi-point fuel injection, and use the distributer, ecu, and intake manifold setup off a 90-91 integra (obd0). keep in mind your plug harness is going to be different than the 89-91's. 88 is unique in that, when you plug everything in your tps will be reading backwards and you will get a code 14 (iacv) so those issues will need to be addressed after the multipoint and everything else installed
Old Sep 8, 2006 | 01:38 AM
wunPOINTeight's Avatar
hit up droppedcrxsi he can help you out so everything will be plg n play
rywire.com ftw!!!
Old Sep 8, 2006 | 09:01 PM
Rukusmasta2's Avatar
Default Re: (wunPOINTeight)
this has been covered numerous times...search and u shall find lots of answers
Old Sep 9, 2006 | 07:50 PM
nitroracer's Avatar
Default Re: (Rukusmasta2)
thanks for the replys guys, yes i have searched, but i guess not correctly
DomkeBoy
Aug 10, 2012 07:58 PM
accord2civic2prelude
Aug 14, 2009 05:42 AM
93siturbo
Apr 10, 2009 06:22 PM
myEK=slow
11
Aug 21, 2006 08:20 PM
0ptimus prime
Aug 20, 2004 09:14 AM
