installed tractionbar/cross member car pulls to the left now?
i just installed my innovative crossmember/traction bar. My car now pulls to the left a little. did i over tightened the radius arms on one side only? i dont get it.
Thats what it sounds like to me. Your drivers side is a little to tight. I have the Z10 bar on mine and I never ran into this problem, but then again I made sure they were both even...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsca_crx »</TD></TR><TR><TD CLASS="quote">double check the install. get an alignment. solved.</TD></TR></TABLE>
I agree with this fool. I would say the exact same thing.
i double checked and thought they were pretty even. ill check agian this weekend i guess.
as for allignment i was hoping i wouldnt have to do that cause every shop here is a total joke and since my car is lowered they charge me a mod fee which ends up costing me 113 bucks for an fing 15 min allignment
unless the bar itself was welded crooked it should be fine(this is the bar that uses the stock radius rods right?) you cannot overtighten the radius rod bushing there is a metal sleeve inside to prevent that. just get an alignment and if caster is different than before the bar was made wrong
HT Chaplain
Mar 1, 2006 06:43 PM
oeklm
10
Dec 24, 2003 04:47 PM
arsenaldragster
Jul 31, 2003 09:40 PM
