Quick newb bulb question
So my winter car needs a few bulbs. It's a 91 LX. Needs cornerlight bulbs. Double checked my cheap AutoZone Haynes manual and it says 1 screw on top and pull. So i had a few mins before school so i tried it..no go. Pulled and pulled and pulled. No other clips or screws visable to me. Had to leave for school so couldn't keep workin at it. Any tips for me? Thanks!
well keep pulling cause thats it just one screw but it is kind of going to be stuck dont be to worried about it its going to be hard the first time just cause you dont want to risk breaking the light but when you do get it there are two like pin things in the back and one in the front that acts as a bolt tip thing and thats why its kind of hard good luck and hope that helps
Yep if it's like my 96 there is that one screw on the top then I used a flat blade screw driver to put in the side at the back and help pry out. Make sure you pull straight though as the clips break easily if you don't.
nkato
Jan 19, 2003 01:55 PM
