I'm in a delima
Old Sep 6, 2006 | 06:43 PM
JFG Kevin's Avatar
Default I'm in a delima
Just found out that my GSR block needs to be machine. I figure if it needs to be machine i should just bore it out, but i dunno to where i should bore it out to. So i was also thinking about buildind a B20b Vtec would be cheaper. Which way would you go? I want it to be reliable too..
Old Sep 6, 2006 | 06:44 PM
honda_mike's Avatar
throw a b16 head on the gsr block
Old Sep 6, 2006 | 07:30 PM
B20C5 Turbo's Avatar
New User
Default Re: I'm in a delima (aznstyler119)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznstyler119 &raquo;</TD></TR><TR><TD CLASS="quote">I figure if it needs to be machine i should just bore it out, but i dunno to where i should bore it out to.</TD></TR></TABLE>
Don't go past 82mm with the stock sleeves. If you want to use B20 pistons (84mm), have the block sleeved.
Old Sep 6, 2006 | 07:34 PM
UncleD's Avatar
Default Re: I'm in a delima (B20C5 Turbo)
87&gt;89. Do the gsr block.
Old Sep 6, 2006 | 08:49 PM
JFG Kevin's Avatar
Default Re: I'm in a delima (clean rice)
Hum...so you guys recommend machining the GSR block huh....interesting..any particular reason to that?
Old Sep 6, 2006 | 08:58 PM
Aquafina's Avatar
If the ladies know you're resleeved and big bore, your days as a bachelor are over.
Old Sep 6, 2006 | 09:00 PM
gldndrgn14's Avatar
Default Re: (honda_mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_mike &raquo;</TD></TR><TR><TD CLASS="quote">throw a b16 head on the gsr block</TD></TR></TABLE>
then he would have to buy a new head, and redo his block. whats the point in that? the gsr head will have higher compression, and imho is a better head. but thats my opinion. so no war about that.
id say find a good b20long block and put your head on that. b20s are cheap.
Old Sep 6, 2006 | 09:22 PM
JFG Kevin's Avatar
Default Re: (gldndrgn14)
Yah b20 would be cheaper, but i dont want something that will blow on me AGAIN...
wesley_925
Jun 29, 2008 12:16 AM
jdmgeezer
Feb 24, 2008 05:32 PM
mycivic93dx
Aug 31, 2006 05:51 PM
B18C Turbo
Jul 15, 2006 12:03 PM
hondachris1994
Apr 7, 2006 03:10 PM
