p28 trouble
Old Sep 6, 2006 | 06:29 PM
turbo77nyc's Avatar
Default p28 trouble
I recently installed a p28 ecu(chipped ,mapped for 450cc injectors,dsm)) into my car (99 honda prelude)and once I started it up it trew code 8 and 22 which were not there before,I checked the wiring but it seems to be ok.I heard some places that you should use an obd 1 distributor with a obd1 ecu is that true?The car is idleing like ****.Thanx for any advice
Old Sep 6, 2006 | 07:07 PM
PrecisionH23a's Avatar
Default Re: p28 trouble (turbo77nyc)
You will need an obd1-obd2 ecu harness. The dizzy does not make a difference.
Old Sep 6, 2006 | 10:27 PM
98vtec's Avatar
moderator emeritus
Default Re: p28 trouble (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">You will need an obd1-obd2 ecu harness. The dizzy does not make a difference.</TD></TR></TABLE>
other way around hoss
OBDIIA - OBDI conversion harness which can be purchased from john at http://www.phearable.net
u will also need to tune the engine. A basemap is not perfect.
Old Sep 7, 2006 | 03:52 AM
turbo77nyc's Avatar
Default Re: p28 trouble (98vtec)
I already got the obd1 conversion harness but am getting code 22 and 8 the ecu is good its been tested
Old Sep 7, 2006 | 04:23 AM
you know what I mean. haha.
Old Sep 7, 2006 | 07:14 AM
turbo77nyc's Avatar
Is code 8 in regards to a problem with the distributor?
Wonk Unit
Feb 11, 2007 10:26 AM
6kZ
Jul 23, 2006 08:31 AM
CRXLST
13
Sep 25, 2004 07:32 PM
Danethomp
Apr 22, 2004 06:52 PM
GettaluvR
May 1, 2003 08:23 AM
