steering wheel question
Old Sep 6, 2006 | 05:25 PM
gsrcoupe's Avatar
Default steering wheel question
my car got stollen and the ignition got smashed out so i need to fix it and wondering if i can upgrade to a jdm type r steering wheel none airbag, will this work in my car if i have an airbag? will i need anything extra or will this bolt up?
Old Sep 6, 2006 | 07:48 PM
allstarimports1's Avatar
Default Re: steering wheel question (gsrcoupe)
i belive it should just bolt.
Old Sep 6, 2006 | 07:57 PM
Targa250R's Avatar
be professional
It would help if you actually mentioned what car you have, and what car the steering wheel is coming from . . .
'92-95 Civics can use steering wheels (both SRS and non-SRS) from the DC2/DB8 Integra Type-R.
'96-00 Civics can use steering wheels from the EK9 Civic Type-R (both SRS and non-SRS), EP3 Civic Type-R (SRS only, not EP3 Si), DC5 Integra Type-R (SRS only, not RSX), and AP1/AP2 S2000 (SRS only, not Type-V, not 2006-2007).
If you match the proper wheel to the proper car, it will bolt up directly.
Old Sep 6, 2006 | 08:30 PM
dem0nk1d's Avatar
Default Re: steering wheel question (Targa250R)
Yes you can use it. You'll have to cut your srs plug from your airbag, and strip the wires and solder in a 2 OHM resistor. Not 2.2k not 2k ohm resistor just a plain 2 ohm resistor maybe a 2 ohm 5 watt ohm resistor i did it to my passanger side. Worked like a champ, but also a bunch of trail and error.
Old Sep 7, 2006 | 01:29 PM
gsrcoupe's Avatar
my bad, its a 94 civic. thanx for the info so far guys
Old Sep 7, 2006 | 02:28 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrcoupe &raquo;</TD></TR><TR><TD CLASS="quote">its a 94 civic.</TD></TR></TABLE>
Then you are limited to the wheels from '92-95 Civics and '94-01 Integras. Both SRS and non-SRS wheels from those cars will bolt right up.
ricb20vtec22
22
Jul 22, 2013 11:31 AM
derspi
Acura TSX
Apr 7, 2008 10:27 AM
risktypeS
16
May 25, 2007 07:59 AM
GhOSt_Db8
May 23, 2007 01:57 AM
b16b
Apr 19, 2006 01:14 PM
