Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Coilover sleeves discussion? are they as bad as people say?
Old Sep 6, 2006 | 05:03 PM
Vantage's Avatar
Default Coilover sleeves discussion? are they as bad as people say?
What are your thoughts on coilover sleeve's
I just read in a different thread that they make your car bounce. Is this true?
Next question.
As ive stated before im a NEWB when it comes to suspension. The Difference between a coilover sleeve and a true coilover, is a sleeve doesnt come with the shock/sturt?
If this is true, im guessing using CoilSleeve with OEM Shocks/Struts is a TERRIBLE idea? and they blow up quickly.
Im just asking becuase i am VERY unhappy with my H&R's as many of you know. But id love the idea of an adjustable suspension. I do not have the $$ for a full set of coilovers, as they are 1000+ ( Im in Canada) for a good set, but its only $300 for a set of Skunk2 Coilover sleeves. My other option was H&R race, which is about as low as i want it to be most of the time, but is a little low for daily commuting. Also, since ill be so low regardless i should get new shocks/struts.
Post ur thoughts/coments.
Old Sep 6, 2006 | 05:39 PM
Miracle's Avatar
Default Re: Coilover sleeves discussion? are they as bad as people say? (B18a_CRX)
I have just heard that it is all in how you drive. Stock shocks with coilovers will suffice for a smooth, ideal road DD. But if you plan on any performance type drving, then forget it.
<U>The difference:</U>
COILOVER SLEEVES:
FULL COILOVERS:
* * * NOTICE * * * I do not speak from experience here. Just what I have heard most commonly.
Modified by .Red.EM2 at 8:50 PM 9/6/2006
Old Sep 6, 2006 | 06:00 PM
Vantage's Avatar
its all for DD, but i like a spirited drive sometimes. No Autox
Old Sep 6, 2006 | 06:01 PM
Todd00's Avatar
I said I don't want a title!
Sleeved coilovers are normally linear springs, menaing they are not progressive. This is what causes the rougher ride.
Stock springs and all lowering springs I have seen for the 01-05 Civic are progressive springs, meaning the spring gives a soft initial ride, then increases in springrate when pushed.
But either type coupled with crappy stock shocks will give you a less than 'sporty' ride.
Full coilovers have their own shocks with ride and shock adjustment (normally). The spring is matched to the shock, so they can provide a decent ride or a firm ride, depending upon how stiff the setup is and what they were maqde for (street, race, etc).
Old Sep 11, 2006 | 08:22 PM
Sean DM's Avatar
Default Re: Coilover sleeves discussion? are they as bad as people say? (Todd00)
coilover sleeve on our c ars is.. diffrent
take my advise and buy expensive coilovers if you do
if not then you will have a stiff hard ride
Old Sep 11, 2006 | 08:46 PM
toyomatt84's Avatar
Sanji
Compared to my sister's replacement springs, my full coilovers ride much nicer. Albeit, it's a little bit stiffer, overall (custom spring rates), it still doesn't quite have the "teeter-totter" effect when driving on a road with a washboard feel to them.
Old Sep 14, 2006 | 05:59 PM
vtec4lyfe's Avatar
coilover sleeves in the cheap alternative to buying coilovers but in the end you will just end up spending more money when your stock struts go in a month. My opinion is to just save your money for complete coilovers!
Old Sep 14, 2006 | 06:02 PM
brjhnson's Avatar
Default Re: (vtec4lyfe)
I have to say just save and get a full coilover system. I have tien ss and i love the ride and the ride hieght. Plus i feel important haha.
Old Sep 15, 2006 | 07:30 PM
Boilermaker1's Avatar
If you have shocks that can handle the spring rates, then theres nothing wrong with sleeves. The problem is most of the shocks available aren't made to handle the rates, so they blow. Konis and GCs are a popular combination, and the konis are valved sufficiently that they'll hold up to the springs. Konis + GCs makes coilovers, and koni dampers are far better than what you're going to get with most "coilovers".
Take it how you want, but I ripped a $2000 set of JICs out of my car, in favor of the far cheaper, but far more flexible and better Koni/GC setup. Took the car on the same track, ran almost 2 sec quicker a lap with the suspension changed, all other things remaining equal, including the alignment. They're shiny colored, and cost a lot, but a lot of them are not all they're cracked up to be.
crazyguy
Sep 4, 2007 05:45 AM
ej1black
17
Jul 19, 2007 08:13 AM
shyboy817
Suspension & Brakes
22
Aug 25, 2005 11:30 AM
IMMORTAL-B18
Jun 9, 2004 08:03 PM
EkR
Dec 14, 2003 04:51 PM
