Need to get rid of a Mant. Reqd Light?
Old Sep 6, 2006 | 03:05 PM
jdm_bones's Avatar
Default Need to get rid of a Mant. Reqd Light?
Here is the deal, my brother just bought a 94 RS this weekend, but it has a Mant. Reqd Light on...Now on my 99 LS, all you do is push a squre like button that is under the steering colum, to delete that light...Correct me if I am wrong, but arn't all 94-01 Integra's the same, as far as having this button...I've tried disconnecting the battery, dissconecting the ECU, and both at the same time, with no hope...I don't want to just remove the bulb from the cluster...Does any one have any awnsers to my problem? Does this year and make not come with this option? What is the deal? Was this button removed? I need some answers, please...
Old Sep 6, 2006 | 03:21 PM
atg1290's Avatar
Usually you press the buttom but it might not be included with the rs??
Old Sep 6, 2006 | 03:24 PM
.brian.'s Avatar
you have to put your key in the ignition and turn it to acc, then press the button
Old Sep 6, 2006 | 03:28 PM
jdm_bones's Avatar
Default Re: (atg1290)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atg1290 &raquo;</TD></TR><TR><TD CLASS="quote">Usually you press the buttom but it might not be included with the rs?? </TD></TR></TABLE>
Yeah, I need to know, cause it's starting to bug me out! So if that is the case, how would I go about clearing it, there has to be away?
Old Sep 6, 2006 | 03:31 PM
eric22p's Avatar
Default Re: (jdm_bones)
hes right u need the key in ignition
jdm_bones's Avatar
Default Re: (.brian.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .brian. &raquo;</TD></TR><TR><TD CLASS="quote">you have to put your key in the ignition and turn it to acc, then press the button</TD></TR></TABLE> There is no button...
Old Sep 6, 2006 | 03:33 PM
jdm_bones's Avatar
Default Re: (eric22p)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eric22p &raquo;</TD></TR><TR><TD CLASS="quote">hes right u need the key in ignition </TD></TR></TABLE> yeah Iam aware of that, but there is no button!
Old Sep 6, 2006 | 03:45 PM
-Championship-'s Avatar
76.169.175.137
right above the gas pedal, its really really small so you have to get a flash light and just look, dont ask anymore
Old Sep 6, 2006 | 03:50 PM
no2unenolife's Avatar
sit in the car. it is above the gas pedal. straight across from your right knee.
.brian.'s Avatar
http://www.team-integra.net/se...D=164
Old Sep 6, 2006 | 03:52 PM
^^ beat me to it =p
Old Sep 6, 2006 | 03:56 PM
jdm_bones's Avatar
Default Re: (CW_98gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW_98gsr &raquo;</TD></TR><TR><TD CLASS="quote">right above the gas pedal, its really really small so you have to get a flash light and just look, dont ask anymore</TD></TR></TABLE> Look dude, I have to other Integra's check the damn sig...I know where the button is located, and I am telling you there's not one in this one, it was probbably removed...So don't tell me to not ask anymore guy...I am trying to to find an alternate awnswer! If you don't have one, please don't comment...Thank you!
Old Sep 6, 2006 | 04:24 PM
atg1290's Avatar
Wait a min...if the itnerior was swapped it might not be there, swapped mine and had to go back and put it back on..
Old Sep 6, 2006 | 04:46 PM
jdm_bones's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atg1290 &raquo;</TD></TR><TR><TD CLASS="quote">Wait a min...if the itnerior was swapped it might not be there, swapped mine and had to go back and put it back on..</TD></TR></TABLE> This might I've happened, I really didn't get the history of the car, like I said it's my brothers...Well, does anyone know how to reset, without this button...I am positive now, that it has been removed. I have no camera, or else I'd take a picture and post it, but there is not a button...Thanks to those who have helped, now I have to figure out an alterate solution to this damn problem...
Old Sep 6, 2006 | 06:27 PM
CleanLikeJdm's Avatar
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_bones &raquo;</TD></TR><TR><TD CLASS="quote"> now I have to figure out an alterate solution to this damn problem...</TD></TR></TABLE>
Pop the cluster, and take the light out ..
Old Sep 7, 2006 | 06:43 AM
jdm_bones's Avatar
Default Re: (CleanLikeJdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLikeJdm &raquo;</TD></TR><TR><TD CLASS="quote">
Pop the cluster, and take the light out ..</TD></TR></TABLE> yeah, I really didn't want to do that, but I guess that's what I am going to do...
Old Sep 7, 2006 | 07:07 AM
Hype-R Stalker
It's not any type of warning light for anything critical, just a reminder.
So there really isn't any harm in taking it out anyways, it's just an eyesore.
Old Sep 7, 2006 | 08:57 AM
jdm_bones's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLikeJdm &raquo;</TD></TR><TR><TD CLASS="quote">It's not any type of warning light for anything critical, just a reminder.
So there really isn't any harm in taking it out anyways, it's just an eyesore.</TD></TR></TABLE>
yeah, I am a damn perfectionest when it comes to fixing things...So this will be an eye sore for awhile, untill I figure something out...
Old Sep 7, 2006 | 10:12 AM
Racermech's Avatar
96RS here and it does have the button.
Old Sep 7, 2006 | 11:51 AM
atg1290's Avatar
just go find one!
Old Sep 7, 2006 | 12:26 PM
JohnnyB70's Avatar
Is there any evidence of the plug that should go into the maintence reset box? If you have the plug take one out of your teg and plug it in and reset it.
Old Sep 7, 2006 | 01:43 PM
jdm_bones's Avatar
Default Re: (JohnnyB70)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnyB70 &raquo;</TD></TR><TR><TD CLASS="quote">Is there any evidence of the plug that should go into the maintence reset box? If you have the plug take one out of your teg and plug it in and reset it.</TD></TR></TABLE>
Yeah, I was looking for that too, but no signs of it...Damn, now I want to remove the whole dash to check out the rest of the wireharness, I hope it's not all cut up...
s2kkk
Honda S2000
10
Aug 12, 2007 12:27 PM
Ash81
Jan 21, 2007 12:54 PM
wreckeddc4
Feb 15, 2006 10:48 PM
SPOON_BeIgHtEeNsEe
Acura TL, RL & ZDX
Jan 29, 2004 03:47 PM
tweak
Jan 13, 2004 08:21 AM
