Stock oil pressure sending unit ? Remove?
Old Sep 6, 2006 | 11:40 AM
ls1tjw's Avatar
Default Stock oil pressure sending unit ? Remove?
If I remove the stock oil pressure sending unit will it throw any codes? I have a 99 prelude converted to obd I.
Old Sep 6, 2006 | 12:10 PM
bb_one's Avatar
Default Re: Stock oil pressure sending unit ? Remove? (ls1tjw)
Your oil light will come on, but that should be it.
Old Sep 6, 2006 | 12:13 PM
ls1tjw's Avatar
Default Re: Stock oil pressure sending unit ? Remove? (bb_one)
I figured it would. I'm running out of room for oil ports.
Old Sep 6, 2006 | 01:00 PM
H22Luda720's Avatar
What all are you trying to feed?
Old Sep 6, 2006 | 01:48 PM
PrecisionH23a's Avatar
I would leave it in. Just run a brass tee at the sending unit or the greddy oil sandwich plate at the oil cooler/filter.
Old Sep 6, 2006 | 02:23 PM
ls1tjw's Avatar
Default Re: Stock oil pressure sending unit ? Remove? (PrecisionH23a)
I have a brass T right now but its very long and fear it will break. I wanted to get the sandwitch adapter but I don't think they make one for my car because on my engine that is my oil cooler. I have the stock sending unit, turbo feed line, and oil pressure guage sending unit (real guage).
Old Sep 6, 2006 | 02:38 PM
The greddy unit will fit... you just have to modify the rear cross member a little bit in order to get a filter to fit. Simply use a grinder wheel to remove about 1/4"-1/2" and it will fit. I've used these on several 4th and 5th gen preludes.
Old Sep 6, 2006 | 02:59 PM
ls1tjw's Avatar
What about the oil cooler?
Old Sep 6, 2006 | 03:07 PM
Eddiebx's Avatar
if ur that worried aoubt snapping the t, just run a braided line from the block to the firewall or soemthing, and then u can t-off as many things there w/o fear of breakign anythig,
Old Sep 6, 2006 | 03:30 PM
ls1tjw's Avatar
Default Re: (Eddiebx)
no thanks
javantie
Apr 22, 2015 02:10 PM
creechrr
Jan 2, 2007 02:04 PM
9hatch6
17
Apr 24, 2005 04:08 PM
yusoslo
Apr 2, 2004 11:47 AM
boosted_dc2
Mar 17, 2003 11:42 AM
