Help me save my REX =(
I used to have a code 16 which i thought is the injector then someone suggested to replace the main relay which i did , now i dont have any hot day start up problem.
after autocrossing last week , a crazy problem poped up , in the middle of my run , my car just died without any reason.
i then pull out the ecu and saw a code 15 , i read the faq and did a check but couldnt find much info to verify which part is bad.
i check the connection it seems good , how do i know if i have a bad ecu? because i am afraid i fried mine from resetting too much.
and the c211 connector , it's just dangling there i bought the car like that and there is no bracket. i dont know if it might be that problem but evertime it dies , i go out and pop the hood and try to squeeze the connector harder and it will start back just fine. or should i get an ecu?
hate when this happens when im on the main street or the highway , it's just embarassing and troublesome i have to push my car to the road side.
From: I told you to wait in the truck in Texas, United States
Code 15 =ignition output signal
usually the ignitor..
Also check the wires going to it for connection problems.
https://honda-tech.com/zerothread?id=468260
Instead of squishing the connector. Try to push the wires towards each other.
This will push the contacts inside the connector together.
do you think zip-tieng the wires like you said pushing it together would work ?
where can i located the ignitor? and how to know if its faulty or its the faulty ecu?
i cut off the rubber thing on the c211 connector cause i cant reach the connector with it on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX »</TD></TR><TR><TD CLASS="quote">Code 15 =ignition output signal
https://honda-tech.com/zerothread?id=468260</TD></TR></TABLE>
yea i did exactly according to that website. no dice though.
sometimes its ok and sometimes its not , its making me afraid to drive it out as it would be dangerous
can you try a different ECU.. borrow a friends? and also maybe try a different distributor..
I had problems similar to that at two seperate times.. both times it was distributor related
hmm...sorry from deviating from the discussion here..but i'm throwing a code #16 rite now..i replaced the main relay's nothing...made sure everything was grounded..nothing..jsut did a MPFI but haven't gotten the car fired up yet...
allm0torGSR
Apr 30, 2004 05:10 PM
