Ls/vtec questions
1) On my gsr I had a pvc system, but with the b18b block there are no black box for the pvc valve to go into. Should I leave it hanging there sucking on air from out side?
2) I relocated the knock sensor but broked it, can I run an engine management system that will not need a knock sensor? Or does knock sensors give you more power?
3) Any way to clean a used O2 sensor?
dem0nk1d
Feb 13, 2007 07:11 PM
