Suspension & Brakes Theory, alignment, spring rates....
Front Civic 99-00 si sway bar on Civic 92
Old Sep 6, 2006 | 01:12 AM
PARADOX_sf's Avatar
Default Front Civic 99-00 si sway bar on Civic 92
Is it possible? What i need to do?
Today i check EG sway bar and it is 22mm.
Thanks.
Old Sep 6, 2006 | 07:26 AM
RacerXI's Avatar
Default Re: Front Civic 99-00 si sway bar on Civic 92 (PARADOX_sf)
That front bar is a 26mm and you'll need the LCA's at the least. Someone correct me if i'm wrong.
Old Sep 6, 2006 | 08:24 AM
Relic1's Avatar
end links and the correct size inner bushings is all you'd need. Other wise it's bolt in... if you have an OEM sway in there all ready.
BTW, 26mm in the front is too much understear IMO.
Old Sep 6, 2006 | 11:23 AM
hayabusa160's Avatar
you will need the si front lca to use that sway bar.
Old Sep 6, 2006 | 12:48 PM
Relic1's Avatar
Default Re: Front Civic 99-00 si sway bar on Civic 92 (hayabusa160)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hayabusa160 &raquo;</TD></TR><TR><TD CLASS="quote">you will need the si front lca to use that sway bar. </TD></TR></TABLE>
first post... he has a 22mm on there now so I'd bet he has an EX or SI now.
Old Sep 6, 2006 | 02:31 PM
PARADOX_sf's Avatar
Default Re: Front Civic 99-00 si sway bar on Civic 92 (Relic1)
My car is EG6 and it have 22mm fornt and 15mm rear sway bars. I plan to upgrade them with 26m Si front and 23mm type-r rear way bars. Is this a good idea or not?
Old Sep 6, 2006 | 02:49 PM
Relic1's Avatar
I run the 26/23 combo right now.
understeer all the time except for serious mid corner braking.
I'm planning to drop in a 24 front to hopefully get the rear to rotate a little more. (24mm is from a DC2)
22mm is next after that if I'm not happy yet.
IMO stick with the 22 front and try the 23mm rear on for size. The rear is easy to install and you can always drop in a 24mm or 26mm if you feel that the rear comes around too easily.
Old Sep 7, 2006 | 12:23 AM
PARADOX_sf's Avatar
Default Re: (Relic1)
Thanks!
Old Sep 7, 2006 | 02:33 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (PARADOX_sf)
The 99-00 Si front sway-bar end-links will not hook up to an EG front LCA, even if it is the version made for a sway-bar. The reason is because the 99-00 Si end links have ball-joints at both ends that make a 90* turn. The 22mm sway-bar end-links won't hook up to a 26mm sway-bar (or 24mm for that matter) for the opposite reason. To use the 26mm front bar, you would have to use the 99-00 Si end-links, front LCAs AND the front damper forks (wider fork bushing ). This is just silly for a mod that increases your tendancy to understeer and also further reduces the amount of caster that the EG front suspension is already seriously lacking...
Stay 22mm...
Old Sep 7, 2006 | 09:06 PM
Relic1's Avatar
Default Re: (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">To use the 26mm front bar, you would have to use the 99-00 Si end-links, front LCAs AND the front damper forks (wider fork bushing ). </TD></TR></TABLE>
actually the teg end links work. Balljoint at both ends, top is a right angle.(that's what I run)
Stay 22mm...</TD></TR></TABLE>
I'm agreeing 110%
I have the 26mm in the front and do not like it at all. (as I said above)
Old Sep 8, 2006 | 04:04 AM
autox228's Avatar
i have an eg too but i was wondering do u guys feel any difference wit the front sway bar?
Old Sep 8, 2006 | 07:13 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (autox228)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by autox228 &raquo;</TD></TR><TR><TD CLASS="quote">i have an eg too but i was wondering do u guys feel any difference wit the front sway bar? </TD></TR></TABLE>
After going from NO front sway-bar to a 24mm GSR front sway, I can tell you the difference in feel is night & day. Weather or not the effects will increase over/under-steer will only be seen by testing (which I don't do on my street car). I can tell you that roll was reduced significantly. The feel is great, and it made a much bigger difference than just adding a 14mm rear sway...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">actually the teg end links work. Balljoint at both ends, top is a right angle.(that's what I run)</TD></TR></TABLE>
Do you mean GSR end-links? They have the ball-joint only at the end that connects to the sway-bar. If so, thats good to know. Thanks...
Old Sep 8, 2006 | 07:20 AM
Relic1's Avatar
Default Re: (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">Do you mean GSR end-links? They have the ball-joint only at the end that connects to the sway-bar. If so, thats good to know. Thanks... </TD></TR></TABLE>
they might be the ITR end links then. There is a ball joint on both ends.
Old Sep 8, 2006 | 09:32 AM
94eg!'s Avatar
#1 Super Guy
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">they might be the ITR end links then. There is a ball joint on both ends.</TD></TR></TABLE>
ITR is the same as the GSR (ball-joint at one end). Only the 99-00 Si end-links have a ball-joint at both ends. Please explain how you attached the ball-joint end to a regular EG LCA. If you have a picture of the setup that would help imensly...
GSR/ITR front suspension (#2 and #6):
99-00 Si front suspension:
Old Sep 8, 2006 | 01:40 PM
autox228's Avatar
Default Re: (94eg!)
would an LS sway bar work ok? also how big is an LS one?
Old Sep 8, 2006 | 01:51 PM
94eg!'s Avatar
#1 Super Guy
Loved
The LS sway-bar is the same 22mm as the regular Civic front bar. Yes it would work...
Old Sep 8, 2006 | 01:57 PM
autox228's Avatar
Default Re: (94eg!)
koo cuz i have an LS as a parts car so imma take it off the car... plus i jus got me 22mm itr rear sway bar.. hope it handles well wit my EM racing bars too
Old Sep 8, 2006 | 03:45 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">...(24mm is from a DC2)...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">The LS sway-bar is the same 22mm as the regular Civic front bar. Yes it would work...</TD></TR></TABLE>
Are both of these posts true? Did the GSR and ITR come with a larger front bar than the rest of the tegs? I though all G3 tegs came with the same front bar.
I'd really like to find a smaller bar than my 00 gsr came with...
Old Sep 9, 2006 | 07:06 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (TunerN00b)
Yes it's true. In the following picture, bar #1 is the RS/LS 22mm, and bar #2 is the GSR/ITR 24mm.
Old Jan 10, 2007 | 01:40 PM
PARADOX_sf's Avatar
Default Re: (94eg!)
It is impossible to install 26mm Si bar on civic EG !!!
1EK1EG
Northern California (Sales)
Jan 19, 2013 05:29 AM
italian_virus
Jun 25, 2010 09:11 PM
SoullessJapaneseMachine
Suspension & Brakes
Oct 10, 2007 07:43 PM
Malakai
Jul 9, 2006 01:39 PM
Mr. Choi
Aug 5, 2003 01:33 PM
