What internals should i use in my b18a1 block?
Old Sep 5, 2006 | 08:21 PM
jdmbeegee's Avatar
Default What internals should i use in my b18a1 block?
I am trying to figure out what rods and pistons i should use in my b18a1 block
I have b16 rods but not sure if they would down grade the motor
I also have stock ls rods and pistons
but i want to know if i use ls rods what pistons i should use?
Old Sep 5, 2006 | 08:38 PM
crxnj's Avatar
Default Re: What internals should i use in my b18a1 block? (jdmbeegee)
the b16 rods wont work they're to short..
do you want a higher compression or lower compression? if you want lower just stick with the ls pistons,if you want a bit higher get the b16 pistons
Old Sep 5, 2006 | 08:39 PM
jdmbeegee's Avatar
Default Re: What internals should i use in my b18a1 block? (Mr.speaker)
o ok ya i want higher so ya should i just use ls pistons and rods in that case
Old Sep 5, 2006 | 08:44 PM
jdmbeegee's Avatar
ha never mind i misunderstood u
Old Sep 5, 2006 | 08:55 PM
digitally_remastered's Avatar
get some wiseco pistons and eagle h beam rods. then get your head ported and polished with some new high performance values and springs, and some gsr cams. then if ya wanna have some fun, throw 10psi in and call it a day.
Old Sep 5, 2006 | 09:04 PM
ViF CrX's Avatar
Default Re: (digitally_remastered)
gets p30's
Old Sep 5, 2006 | 09:58 PM
HFpower's Avatar
p30 pistons on Ls rods
Old Sep 5, 2006 | 10:04 PM
oO Ls VTEC Oo's Avatar
Default Re: What internals should i use in my b18a1 block? (HFpower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HFpower &raquo;</TD></TR><TR><TD CLASS="quote">p30 pistons on Ls rods </TD></TR></TABLE>
x2
ez2000si
Mar 4, 2013 01:12 PM
Demerica333
Aug 26, 2009 05:47 PM
whitehatchguy
Apr 18, 2007 06:49 AM
mr.si1
Oct 18, 2006 10:31 AM
RacerBoy
Jan 3, 2003 12:04 PM
