Rear Drum Knocking While Slightly braking
it sounds like someone knocking on a door... i just replaced the shoes/springs to see if that would cure the problem and it did nothing.
it only happens when i push the pedal 50% of the way down.. and it's a fast knock knock knock
but when i press firmly on the pedal it goes away. WTF?!
any help would be great
drums were turned maybe a year ago tops and i adjusted the parking brake after I did the shoes... but like I said.. the noise was there before I changed out the shoes/springs and adjusted the parking brake
hmm try this....Jack the car off the ground, take the wheel and drum off and have someone apply the brakes while you turn the assembly. Try to see if you notice anything rubbing or bouncing, also have you checked your struts cause theyll also make a knocking sound....Give a try and let me know the outcome.
i've tried something like this with the drum off and nothing is rubbing/making noise... makes me wonder if it's the drum itself?!
Also the car is on brand new coilovers as well as every arm/bushing in the rear suspension is new and aftermarket... it's def. coming from the drums under low braking.
didn't shoot down ideas. . . just tried everything everyone suggested besides replacing the actual drum housing.
Looking for someone to say... "yeah... try that.. that's what it should be.."
thanks
thanks
Fernandos_EJ8
Dec 19, 2019 05:35 AM
Leviatard
Jun 30, 2013 12:42 PM
BringIT
Apr 8, 2010 05:16 PM
