state ref question???
My question is what ECu should i be using on a b16a2 in my 98 civic HB?
Im using a P30 right now and i went to get it REf and i faild the visualize but i pass the emission.. he said that i failed the timing which was at 16 insted of 12 and i also failed the EVap collectors can. the ECu. and the CAT (which i fix today)..
i forget exactly which one, but call (tomorrow) your dealership and ask them. besides you will most likely have to bring a print out from the dealership showing proof the ecu you have is the correct one to use on the swap(generally speaking). kill two birds with one stone.
