code 20
Old Sep 5, 2006 | 05:15 PM
211811518's Avatar
Default code 20
1988 civic d15b2, the ecu is flashing 20 times? does this mean i need an ecu? Thanks
Old Sep 7, 2006 | 03:56 PM
211811518's Avatar
Default Re: code 20 (211811518)
anybody got a handle on a code 20? would really appreciate the help. Thanks
Old Sep 7, 2006 | 07:39 PM
CanuckCRX's Avatar
New User
Code 20 is ELD..Electronic Load Detector...as long as the car isnt acting up at all i wouldn't be too concerned with it. It wont affect drivability or anything.
Old Sep 7, 2006 | 07:57 PM
RCautoworks's Avatar
Default Re: code 20 (CanuckCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CanuckCRX &raquo;</TD></TR><TR><TD CLASS="quote">Code 20 is ELD..Electronic Load Detector...as long as the car isnt acting up at all i wouldn't be too concerned with it. It wont affect drivability or anything.</TD></TR></TABLE>
Um, when the check engine light is on the car is in limp mode, meaning more fuel will be tossed at your engine causing you to run rich, check engine light is never good.
https://honda-tech.com/zerothread?id=1508680
Old Sep 7, 2006 | 08:37 PM
CanuckCRX's Avatar
New User
Default Re: code 20 (90blackcrx)
There is no CEL for the ELD, it is just a soft code, does not effect anything. Trust me, if you know anyone running a JDM ECU in their swap, up here in Canada anyways, the ELD code 20 is there. We dont have ELDs in our cars, just in the US and Japan. I have seen it many times.
Old Sep 8, 2006 | 03:56 AM
salman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CanuckCRX &raquo;</TD></TR><TR><TD CLASS="quote">There is no CEL for the ELD, it is just a soft code, does not effect anything. Trust me, if you know anyone running a JDM ECU in their swap, up here in Canada anyways, the ELD code 20 is there. We dont have ELDs in our cars, just in the US and Japan. I have seen it many times.</TD></TR></TABLE>
I also have ELD Issue in my car, but thing are ok even with it,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 211811518 &raquo;</TD></TR><TR><TD CLASS="quote"> flashing 20 times?</TD></TR></TABLE>
The Ecu light Flashes only 2 times for ELD, or to display code 20, your not reading it in the right way,
Old Sep 8, 2006 | 08:08 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: code 20 (salman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salman &raquo;</TD></TR><TR><TD CLASS="quote">
The Ecu light Flashes only 2 times for ELD, or to display code 20, your not reading it in the right way, </TD></TR></TABLE>
Depends on the ECU, on stock ones for this year range EFs they just blink the number of times for the code. (I believe this is true for all OBD0 systems as well). You're referring to the OBD1 style, where you have short and long blinks.
Old Sep 8, 2006 | 09:26 AM
Default Re: code 20 (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">
You're referring to the OBD1 style, where you have short and long blinks.</TD></TR></TABLE>
obd0 is the same
I'll take your word
Old Sep 8, 2006 | 09:53 AM
wiZCo's Avatar
Stouts 'n' Scotch
OK I guess it just depends on the ECU.
Old Sep 8, 2006 | 12:18 PM
211811518's Avatar
Thanks for your help. The car is extremely rich at idle, ok off idle. Is this related to code 20?
Thanks again
Old Sep 9, 2006 | 12:57 PM
211811518's Avatar
Well fellas, I got rid of the code 20!!!!!!!!!!!!, I had almost no ground (extremely high resistance 2.5Mohms) between the battery and chassis. Thanks for all your input
vstone
Jun 1, 2010 09:29 PM
dubnine
Jun 1, 2007 07:00 AM
djcue_530
Mar 15, 2007 08:53 AM
PINKS
11
Jul 13, 2006 06:00 PM
uszcrx
Jul 27, 2003 02:37 PM
