F/s turbo del sol 430hp 350tqe
Lots of pic available just give me an email address to send them to. Dyno sheets available. Asking 14000 obo.
Mods
Engine:
Ls/vtec
Je 9:1 pistons
Crower rods
Darton sleeves
Acl bearings
Type r valves, springs, retainers
Gsr cams
Str cam gears
Bbk 70mm throttle body
Rc 650 injectors
Aem fuel rail, fule pressure regulator, and fuel filter
Msd 6a ignition and blaster 2 coil
Ngk wires
Ngk bkr8e-ix plugs
Equal length ss exhaust manifold, heat wrapped
T3/t04e 57 trim turbo
Hks wastegate
Greddy type s bov
Rev hard intercooler
2.25 charge pipes
Fal fan
Pwr radiator
Full 3” exhaust
Hks titanium turbo muffler
Greddy oil catch can
Fluidampyr crank pulley
Endyne sandwitch adapter
4an line for turbo, 10an for drain, 6an for ls/vtec
ctr tranny with lsd
Act flywheel
clutchnet 6 puck and pressure plate
ingalls “stiffy” engine damper
Hasport motor mounts
Yellow top omni battery
ecu- chipped p28 (stock maps with rev limit raised)
Profec e-01 with emanage
Suspension:
Tokico illumine 5 way adj. springs
Ground control coil overs
Apr front strut bar
Omni power lca
a-spec raicing lower tie bar
type r 22mm rear sway
em racing triangulated trunk braces
cusco subframe brace
Exterior:
Mugen side skirts
Buddy club rear
R34 front with fog lights shaved out
Silver carbon hood, trunk, and splitter
Most lines shaved out, incl. antenna
Volk te37 16’ with volk aluminum lugs
Advan a048’s
Interior:
Momo steering wheel
Momo petals
Niken racing shift ****
Bride knock off seats
Greddy a/f, boost, temp gauges
Autometer lunar tach with shift light
Profec screen for real time adjustments for
Ignition tables, fuel tables, vtec engagement, etc.
Alpine7875 head unit
Focal polykevlar components set
Precision power 2300.2 amp.
Modified by kell211 at 12:38 PM 9/6/2006
Mods
Engine:
Ls/vtec
Je 9:1 pistons
Crower rods
Darton sleeves
Acl bearings
Gsr cams
Str cam gears
Rc 650 injectors
Ngk wires
Ngk bkr8e-ix plugs
Hks wastegate
Greddy type s bov
2.25 charge pipes
Fal fan
Pwr radiator
Full 3” exhaust
ctr tranny with lsd
Act flywheel
Suspension:
Apr front strut bar
Omni power lca
Exterior:
Mugen side skirts
Buddy club rear
Advan a048’s
Interior:
Momo steering wheel
Momo petals
